Car Heater - BMW Forum - BimmerWerkz.com
Old 03-03-2005, 04:42 PM   #1 (permalink)
Deewade is an unknown quantity at this point
I need help on this one guys cause the car temperature is so messed up. I have a 316i E36 saloon. The temperature controls don't seem to be working correctly. Heat to the windscreen and the floor is hot, but the front vents on the dash are cold. I don't seem to have any control over the temperature of the car. If I set the temperature to cold, the windscreen and the floor vents are still coming out hot. If I set the temperature to hot, the front vents on the dash are still blowing out cold air. I definately need help on this one.
Deewade is offline   Reply With Quote
Old 03-03-2005, 05:48 PM   #2 (permalink)
Reedalicious's Avatar
Reedalicious is an unknown quantity at this point
Send a message via MSN to Reedalicious
Year would help, infact what would help more is if you told us if you have digital climate or not.
Reedalicious is offline   Reply With Quote
Old 03-03-2005, 06:07 PM   #3 (permalink)
ganjacyde is an unknown quantity at this point
Send a message via AIM to ganjacyde Send a message via MSN to ganjacyde
sounds like you have your top vents set to cold. underneath of the top vent in the middle of the dash, right next to where the open/close vent thing is, is a control for hot/cold. just turn it over to the red and heat should be coming out.
<embed src="http://www.svcountryclub.com/upload/e36m42.swf" width="420" height="140" background="none" menu="false">
ganjacyde is offline   Reply With Quote
Old 03-04-2005, 11:13 AM   #4 (permalink)
[snapback]303383[/snapback]
Its the 95 model. I don't have the digital control, its the basic analogue style.
Old 03-04-2005, 03:48 PM   #5 (permalink)
frank3 is an unknown quantity at this point
Originally posted by Deewade+Mar 4 2005, 10:13 AM--><div class='quotetop'>QUOTE(Deewade @ Mar 4 2005, 10:13 AM)</div><div class='quotemain'><!--QuoteBegin-Reedalicious@Mar 3 2005, 11:48 PM
[snapback]303794[/snapback]
[/b][/quote]
Ya didn't mention if moving your knob below the middle vents from blue to red solved your problem. That sure sounds like it could be the cause of the cold air.
<span style='color:green'>1994 325i </span>- - - 75,000 mi.
No mods - - - very happy as is!
<span style='color:green'>1995 525i </span>- - - 154,000 mi.
No squeaks or rattles... unreal!
frank3 is offline   Reply With Quote
Old 03-04-2005, 10:15 PM   #6 (permalink)
xorbital0's Avatar
xorbital0 is an unknown quantity at this point
Send a message via Yahoo to xorbital0
Anyone know why my hot air smells like antifreeze sometimes? and in cold weather the vents release and odd fog.
xorbital0 is offline   Reply With Quote
Old 03-04-2005, 11:15 PM   #7 (permalink)
[snapback]304110[/snapback]
You've got a leak somewhere in your heating system...could be a hose. When you turn the heat on, hot radiator coolant flows through the interior heater and the fan blows air over the heater providing hot air. Check hoses.
Old 03-06-2005, 05:24 PM   #8 (permalink)
Originally posted by frank3+Mar 4 2005, 09:48 PM--><div class='quotetop'>QUOTE(frank3 @ Mar 4 2005, 09:48 PM)</div><div class='quotemain'>
[snapback]303952[/snapback]
[/b][/quote]
Moving the know from blue to red doesn't seem to do anything.
94 m-technic in AZ adamsbomb Cars For Sale 8 12-14-2005 11:43 PM
Z3 Heater not working properly b_OASIS 1,6,7,8 - Series and Mini Cooper 1 10-28-2005 03:56 PM
problems starting car when cold... VLAD_325is 3-Series (E36) 8 09-12-2005 08:08 PM
Heater Core ? walshja 3-Series (E36) 8 01-19-2005 05:39 PM
