Cant Figure Out How To Check My Engine Codes? - BMW Forum - BimmerWerkz.com
Old 12-06-2004, 11:00 PM   #1 (permalink)
streetdreams is an unknown quantity at this point
Ok my check engine light is on and Im trying to read the codes by turning the key to on, waiting till the 2nd lights go out after about 2 seconds then hitting the gas all the way down quickly as possible 5 (probably more) times. Nothing happens. My car is a 92 325i, does this method work for my car?
streetdreams is offline   Reply With Quote
Old 12-06-2004, 11:09 PM   #2 (permalink)
Kevin325i's Avatar
You've got to press it 5 times IMMEDIATELY after turning the key to the first position. Before the 2nd lights go out.
Try again and report back.
Kevin (President TBEA)
Old 12-07-2004, 05:05 AM   #3 (permalink)
Super Moderator
dutchbmw's Avatar
Consider about buying this: http://www.peakeresearch.com/products.htm
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 12-07-2004, 10:10 AM   #4 (permalink)
frank3 is an unknown quantity at this point
I finally got the codes to read out...can't figure out what I did differently this time...turn the key, push the gas 5 times. Cool. I got a "1444" reading - meaning no faults! Yahoo!
<span style='color:green'>1994 325i </span>- - - 75,000 mi.
No mods - - - very happy as is!
<span style='color:green'>1995 525i </span>- - - 154,000 mi.
No squeaks or rattles... unreal!
frank3 is offline   Reply With Quote
Old 12-07-2004, 11:12 AM   #5 (permalink)
Super Moderator
dutchbmw's Avatar
Is there anyone who can take a pic of the 'check engine' light?? I'm not sure but I think there's none on my dash.
BMW '96 M3 (SOLD)
Old 12-07-2004, 01:14 PM   #6 (permalink)
Sweet! I figured it out. Im throwing code 1222. Which is the O2 sensor. Is this why my car idles wierd until the car warms up? Also I thought the engine was supposed to give a code and then stop flashing? My light kept repeating the same code over and over. -Thanks
Old 12-07-2004, 01:51 PM   #7 (permalink)
[snapback]245191[/snapback]
It's approximately above your steering wheel on your car and simply says "Check Engine". If you don't see it when you put your key in and turn it to the #2 position, then most likely your light is burned out.
Check Engine Light E46 '04 M3 frw73 M-Series (M1, M3, M5, M6) 4 08-24-2004 10:20 PM
check engine light and check light Scarface 3-Series (E36) 3 06-03-2003 08:31 AM
service questions thamindzzeye 3-Series (E36) 4 04-30-2003 02:40 PM
