Can't get into my car - BMW Forum - BimmerWerkz.com
Old 01-22-2004, 07:35 AM   #1 (permalink)
Boost's Avatar
Boost is an unknown quantity at this point
Send a message via MSN to Boost
I have searched all over the forum (even the faq about lifting your hood with no access to the interior of the car)
I have the following problem: My battery is empty and the lock on the driver's side isn't working and the door on the other side doesn't have a lock (you can only "beep" it open with the key), now I can't get into my car.
I have tried to go through the trunk but I can't get the rear seats down from the back.
Now i'm trying to remove one of the grills, maybe this way i can get the hood open and my battery recharged.
Does anybody know how to remove the kidney grills on an 1995 (e36) 318is? these grills are hard tot take off (don't wanna break them)or is there an other solution for my problem (Without seriously damaging the car)
Serious help wanted!!!
Thank god I'm an atheïst
Sig under construction!
Boost is offline   Reply With Quote
Old 01-22-2004, 08:00 AM   #2 (permalink)
trinidon2k's Avatar
trinidon2k is an unknown quantity at this point
Send a message via AIM to trinidon2k
your battery is in the trunk not under the hood
trinidon2k is offline   Reply With Quote
Old 01-22-2004, 08:12 AM   #3 (permalink)
Boost's Avatar
My battery is under the hood, i know because I have replaced it once
I can't have 2 batteries, can I??
Old 01-22-2004, 08:15 AM   #4 (permalink)
KingScare's Avatar
Car: 98 M3
KingScare is an unknown quantity at this point
Send a message via MSN to KingScare
I think it's mostly on the e30's that the battery is in the back.
Most bimmers hold it under the hood.
KingScare is offline   Reply With Quote
Old 01-22-2004, 08:18 AM   #5 (permalink)
Boost's Avatar
If the battery was in the back my problem would be solved an i would be again.
Old 01-22-2004, 08:20 AM   #6 (permalink)
Boost's Avatar
Does anybody know how to get the seats down from the trunk btw??
Old 01-22-2004, 08:51 AM   #7 (permalink)
KingScare's Avatar
Car: 98 M3
In newer models you have 2 pull switches that you can yank from the trunk...
but if you dont see those, you probably have a button on top of the seats from the inside.
Those latches, if they were in your trunk, you would see them.
Old 01-22-2004, 08:56 AM   #8 (permalink)
Boost's Avatar
No i don't have those switches...... is there any other way?
As far as i can see i can only lower the seats from the inside
Old 01-22-2004, 09:46 AM   #9 (permalink)
KingScare's Avatar
Car: 98 M3
I dont really know how you could "butcher" the seats into folding down if the switch is inside the car....I dont think it's ever possible.
You would have to open up that hood...i remember some guy posting how to open his hood in the FAQ section...he said something about removing his grill.
Old 01-22-2004, 09:57 AM   #10 (permalink)
bimmerfan620's Avatar
bimmerfan620 is an unknown quantity at this point
Send a message via AIM to bimmerfan620 Send a message via Yahoo to bimmerfan620
ummm.... All I know is my battery in my 325i is in the trunk, there's no space up under the hood for it...your car's an E36 like mine also, so I don't see why it's under the hood??
FOUNDER of the BMW-Forums Michigan Club
<span style='color:green'><a href='http://www.cardomain.com/memberpage/458339' target='_blank'> Car Domain UNFINISHED </a> </span>
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1078289877.jpg' border='0' alt='user posted image' />
bimmerfan620 is offline   Reply With Quote
Old 01-22-2004, 09:57 AM   #11 (permalink)
oh wait, n/m i see you have a 318
Old 01-22-2004, 09:57 AM   #12 (permalink)
Boost's Avatar
Ok how do you remove those grills??
If i pull any harder im affraid they'll break
Old 01-22-2004, 09:59 AM   #13 (permalink)
there are clips on the top of them, and directly in the middle on the sides. They are just basic push tab style clips.
do you want me to take my grill out and take a digital pic so you can see how to do it?
Old 01-22-2004, 10:03 AM   #14 (permalink)
Boost's Avatar
Yeah that would be great
thnx man
I think the 323i has the same grills
Old 01-22-2004, 10:37 AM   #15 (permalink)
ok i'll be right back with the pic stay here to see it ok
94 m-technic in AZ adamsbomb Cars For Sale 8 12-14-2005 11:43 PM
problems starting car when cold... VLAD_325is 3-Series (E36) 8 09-12-2005 08:08 PM
