Can I use HK speakers with non-HK amp? - BMW Forum - BimmerWerkz.com
Old 10-17-2011, 11:10 PM   #1 (permalink)
hownnq is on a distinguished road
Hi, I have a question on audio upgrade from non-HK speakers to used HK speakers with non-Hk amp?
My M3 has stock non-HK system of 1998.
Recently I bought two pieces of door speakers, so I want to install the speakers instead of the non-HK door speakers.
Is it no problem?
(No sound, smaller sound or something)
If it is OK, I will try to purchase for used HK amp.
Pls let me know.
Tks
hownnq is offline   Reply With Quote
Old 10-18-2011, 05:50 AM   #2 (permalink)
dyn2liv's Avatar
Car: Red 96 318is
dyn2liv is on a distinguished road
You need to look at the ratings for the speakers and the amp. Using speakers with different impedance values than an amp is rated for can cause serious issues. Most factory car stereos run odd-ball ohm values on the speakers so the more speakers can be series or paralleled to a single amp. Important fact here is, know what load the speakers are going to place on the amp and what the amp can handle prior to wiring it. Knowing these values will dictate how it is wired or if it should even be wired up. Need more input check these sites: for diagrams (not free) - http://www.mobileinformationlabs.com...%20systems.htm , good overall audio source - About Amplifiers and more speakers
dyn >
is est, quis is est ...
dyn2liv is offline   Reply With Quote
Can I substitute HK speakers for standard speakers? 2000_328i Audio and Electronics 5 04-24-2007 08:28 PM
E30 Speakers upgrade, cut the chasis or lift the new speakers? fedie 3-Series (E21, E30) 3 07-05-2006 06:27 PM
Speakers numberthree_ 5-Series (E12,E28, E34, E39, E60) 2 08-06-2004 02:42 PM
Speakers iantosca Audio and Electronics 28 05-26-2004 10:41 AM
My back speakers are louder than my front speakers bassrebel Audio and Electronics 9 12-17-2003 12:33 PM
