A/c Question - BMW Forum - BimmerWerkz.com
Old 06-11-2005, 04:45 PM   #1 (permalink)
BeemerMan's Avatar
Car: e36 328is
BeemerMan will become famous soon enoughBeemerMan will become famous soon enough
Hello, my a/c works fine, but my #1 speed doesnt work. 2, 3 , and 4 works fine. Any ideas why 1 doesn't work? fuse maybe? used
BeemerMan is offline   Reply With Quote
Old 06-11-2005, 05:08 PM   #2 (permalink)
quality
Delmarco's Avatar
What you mean level 1 doesn't allow any cold air out...but level 2 , 3 and 4 does?
I usually never use 1 or 2 because it is almost no air at all...I start at 3 for normal and go to 4 for hot days!
Anyway maybe your AC compressor is going (worse case) or your FREON is almost out (not so worse case) but then again the problem would be reversed....4 may not work but levels 3,2 and 1 would.
Old 06-11-2005, 07:43 PM   #3 (permalink)
change your cabin filter.
Old 06-13-2005, 08:20 PM   #4 (permalink)
BeemerMan's Avatar
Car: e36 328is
how do i do that?
Old 06-13-2005, 09:51 PM   #5 (permalink)
quality
Delmarco's Avatar
DIY LINKS:
http://www.mann-hummel.com/mf_prodka...BJPN0FbufV.pdf <-- PDF!!!
http://www.logun.org/microfilter.htm
http://www.koalamotorsport.com/tech/...icrofilter.htm
Or you can read this thread I started last winter:
http://www.bimmerwerkz.com/forum/ind...howtopic=31309
it's funny but it should let you know if u need to change the filter or not.
Another Airbag Light Question storme 3-Series (E46, E90) 8 11-21-2005 01:01 PM
Quick Question About Two Different DDE's... Red93B3M2W5i 3-Series (E36) 4 10-07-2005 12:19 AM
New Receiver Question for 2004 BMW 330i jasyn Audio and Electronics 4 07-12-2004 02:01 AM
Just got my 320i: Small question harpax 3-Series (E46, E90) 18 06-17-2004 04:24 PM
info center in the gauge cluster question audiosolstice 1,6,7,8 - Series and Mini Cooper 3 04-30-2004 02:58 AM
