A/c problem here I got a question ??????? - BMW Forum - BimmerWerkz.com
Old 07-23-2006, 08:29 PM   #1 (permalink)
Car: 1995 BMW 325I
325IConvertible is on a distinguished road
Send a message via MSN to 325IConvertible
I have a 1995 325I convertible and I have owned it for about 4 months now. Since I have had it when turning on the blower knob it has dials of 1 ,2 ,3 and 4 . My 1 , 2 ,3 have never worked but the #4 which is high has always worked with a/c and the heater. Today I was running my A/c and it got a little cold so I turned it off , about 20 minutes later I turned it back on and NOTHING !!!!!!!! 1 , 2 ,3 nor 4 work . The compressor is still coming on but nothing is blowing out of the vents. I have looked online here and have got 2 ideas of what it could be #1 blower motor went out or #2 Resistor to the blower motor..................... What do yall think this could be ???????????? If it is a resistor where is this located ?????? Any kind of help would be gladly accepted.
Thanks David
325IConvertible is offline   Reply With Quote
Old 07-24-2006, 05:48 AM   #2 (permalink)
polaris448's Avatar
polaris448 is an unknown quantity at this point
ok this is definately your blower resistors. i highly doubt that it is the blower motor, if it just stopped working. i think you may have blown a fuse also because in the number four position it bypasses the resistor, if i am reading the wiring diagram correctly. if not the fuse than the blower relay went to shit.
polaris448 is offline   Reply With Quote
Old 07-24-2006, 01:49 PM   #3 (permalink)
e36surge's Avatar
Blower resistor. If I remember correctly you can get to it from the driver side kick panel. Check the Bentley.
- Mario Andretti
1979 320is RiP
1994 318is Sold
1995 325is Sold
1995 530i Sold
2004 M3
Old 07-24-2006, 03:34 PM   #4 (permalink)
Car: 1995 BMW 325I
Kick panel , you mean down by the speaker ? Wouldnt it be more up in the dash part or actually in the kick panel near where the speaker is located ?
Drl Headlamp Relay Problem (daytime Running Light) tonyhon 3-Series (E36) 5 01-18-2005 07:42 PM
Problem with springs? Struts? kraze0g 3-Series (E36) 11 06-30-2004 12:55 PM
A question for you 325 owners JT325is 3-Series (E36) 2 06-24-2004 03:22 PM
Car Accelaration problem eran 3-Series (E46, E90) 2 06-24-2004 12:45 PM
