A/c Help!!! - BMW Forum - BimmerWerkz.com
Old 03-11-2005, 11:14 AM   #1 (permalink)
TeeUp's Avatar
Car: 2002 X5 3.0i and 2007 X5 3.0i
TeeUp is an unknown quantity at this point
here's the condition:
compressor is engaging, drive belt is tight, climate controls are on, air is coming out the vents. the problem: it's not cold. can anyone give me a checklist on what to look for before i go to the stealership?
TeeUp is offline   Reply With Quote
Old 03-11-2005, 12:03 PM   #2 (permalink)
kyle_baker's Avatar
kyle_baker is an unknown quantity at this point
Send a message via AIM to kyle_baker Send a message via MSN to kyle_baker Send a message via Yahoo to kyle_baker Send a message via Skype™ to kyle_baker
well first off. check the coolant level, if it is low, fill it up and problem should be fixed.
this is usually the case. hope this helps
kyle_baker is offline   Reply With Quote
Old 03-11-2005, 12:06 PM   #3 (permalink)
Power Shifting
Cruzin 323is's Avatar
u probably need to refill the freon!
-SOLD..
R.I.P Fast 6
Old 03-11-2005, 12:08 PM   #4 (permalink)
kyle_baker's Avatar
[snapback]308889[/snapback]
Old 03-11-2005, 12:19 PM   #5 (permalink)
NeverLeaned is an unknown quantity at this point
Send a message via AIM to NeverLeaned
Your probably screwed if your car is still run on Freon and need to refill. They'll force you to put the retro fit kit in that runs on the enviromentally friendly freon stuff.
If you need freon, visit as many mechanics as you can and ask them if they have a few canisters of the stuff around. I know one guy in NY that horded them when they changed over a few years back and he does recharges on the sly.
1996- BMW 328IS
<img src='http://img.photobucket.com/albums/v242/gws226/TEX/neverleanedsig.jpg' border='0' alt='user posted image' />
Performance: Zimmerman Cross Drilled Rotors-- PBR Deluxes-- Cosmos CAI---- Turner Pulley Kit--- Fan Delete mod---
Beauty: 18 polished M-Parallel replicas, Inpro Euros w/ Enchanced Angel eye kit, 20% tint
Clear corners/sidemarkers ---- Eurospec (Depos)
To do list:
Suspension--- researching
UUC System U TDM- 3/05
M50 manifold converstion 3/05
NeverLeaned is offline   Reply With Quote
Old 03-11-2005, 12:35 PM   #6 (permalink)
93 325i's Avatar
You just recharge the freon. The new kind of freon is called R134a. You can get this at any autoparts store. My 93 uses R134a so all models above should be as well. THe old freon is R12 which you can still get on ebay, but it is more expensive. Pop the hood and on the passenger side somewhere it should tell you what freon is in your A/C system..
Complete mod list and pics:
My 1993 325i
Old 03-11-2005, 03:12 PM   #7 (permalink)
TeeUp's Avatar
does freon just evaporate over time or lack of freon necessarily mean that there's a leak in my system?
Old 03-11-2005, 03:29 PM   #8 (permalink)
I would test the system for leaks before you waste $$$ recharging.
1996- BMW 328IS
To do list:
Old 03-11-2005, 03:33 PM   #9 (permalink)
TeeUp's Avatar
[snapback]309012[/snapback]
how difficult is that to do in a bimmer?
Old 03-11-2005, 03:38 PM   #10 (permalink)
93 325i's Avatar
It runs out over time.. If you have R134a freon it is like $20-$30 for a recharge kit. If there is a leak I believe the kit comes with somehting that either helps seal leaks or at least detects them..I would get the kit
My 1993 325i
Old 03-11-2005, 07:22 PM   #11 (permalink)
B3M2W5i's Avatar
B3M2W5i is an unknown quantity at this point
Send a message via AIM to B3M2W5i
DO NOT ADD R134A freon if you run on R12 because some chamical in the R134A messes up the seals and will cause your ac system to work that way.. if you hear a ratttling sound while your engine is running you need to change ur ac system, if you dont then fix the problem before that happends because your ac comp. will always be running do to the pully
Cashmere Beige Metallic
B3M2W5i is offline   Reply With Quote
how do you get the a/c off ? j123crx 3-Series (E21, E30) 1 10-15-2005 04:03 PM
Need Help!!! mkhoundara Audio and Electronics 1 08-30-2005 09:43 PM
Engine Problem Help!!! Nitrosport2000 5-Series (E12,E28, E34, E39, E60) 6 08-20-2005 02:18 AM
Help!!! 325i -> M3 Professional Help Required kingsiang 3-Series (E36) 3 10-18-2004 06:00 PM
Help!!! Custom interior trimmings silverbimmer2004 3-Series (E46, E90) 2 01-19-2004 01:32 PM
