Damn... Is this supposed to happen on a 1998 BMW with less than 85 000km (53k miles) on it!?? Even my old 1991 Sentra with 200 000km on it has never done this!!
Is this something really expensive to fix??
Thanks!
H.
Edit: What would go wrong on my car if that problem was present? (ex: bad trottle, ...?)
Hi, i used to have the same problem on my first eva car which was a ford fiesta rubbish i kno!, but neways, it had a brown buttery like substance round the top of the oil cap! and if i cleaned it off more would appear as i drove it!, it was suggested to me that it was water and or air getting into the engine which created this substance! the car did have a massive oil leak! so would explain where the water was getting in! SO THIS MAY BE THE CASE ON YOUR BMW! i would suggest taking it to a reputable garage and have them check all of your oil gaskets and seals! hope this helps!
yes this could be the problem if the air and moisture is gettin in round the cap! is best to have it checked tho as the yellow gunk does not jus build up round the oil cap! it also build up all inside the engine! am sure can be flushed out wit an engine flush but u must ahyve the leak fixed or it will just create more! can ya help me out on my problems in the e36 section :P
it is most likesly condensation. i am a "lube boy" at the local shop and i see it alllllll the time. mostly on the new hemi's and jeeps so i wouldnt go crazy over it.
Originally posted by 323ic@Mar 1 2005, 05:19 AM it is most likesly condensation. i am a "lube boy" at the local shop and i see it alllllll the time. mostly on the new hemi's and jeeps so i wouldnt go crazy over it.
[snapback]301479[/snapback]
This is absolutely correct, more likely to be condensation, looking at your location and if you do short journeys most of the time, the engine never gets to full operating temperature which enables the moisture in the oil to evaporate completely, the only thing you have to be aware of is that if it gets really bad it can start to block up vac pipes and the like.
Someone talked about an engine flush... is there any products you would suggest to do that? Or products you tried and are bad? :P
I presume I drain out my oil (next oil change) then I put a product in engine then let it run a few minutes, drain out again then put back new oil and filter?!
Good news! I went to a BMW specialist shop today, the guy checked my "butter" thing and told me that it was only moisture (it's cold and wet 'round here in Montreal during winter). So he told me to drive the car at least one hour on highway to make this thing evaporate. I did, and... everything went fine, no more brown substance in engine!
Originally posted by Boxbrownie+Mar 1 2005, 01:34 PM--><div class='quotetop'>QUOTE(Boxbrownie @ Mar 1 2005, 01:34 PM)</div><div class='quotemain'><!--QuoteBegin-323ic@Mar 1 2005, 05:19 AM it is most likesly condensation. i am a "lube boy" at the local shop and i see it alllllll the time. mostly on the new hemi's and jeeps so i wouldnt go crazy over it.
Best regards David
[snapback]301628[/snapback]
[/b][/quote]
Glad to hear the BMW specialists know as much as we do around your way!
