Broken Timing Chain 92 E36 - BMW Forum - BimmerWerkz.com
Old 08-10-2005, 10:44 PM   #1 (permalink)
rotaryrex7 is an unknown quantity at this point
On the back straight of Mt Tremblant this past weekend 3 laps into a session I was WOT in 3rd gear pushing just past 6000 rpm when a small pop occurred and the car went dead. The timing chain and the tensioner had come right through the front top of the valve cover. I got the cover off today and found that the small chain that connects the cams was broken. There is still tension on the main timing chain so I am hoping that only the intake valves are bent (there is no compression on any cyl.) The car is a reasonably low mileage car (83k) and is completely stock as I was running it in a showroom stock class until I got the time and money to make it an ITS car.
My questions are what happened and why and thought someone may have had a similar experience? Clearly the chain that connects the cams broke and the valves hit the pistons.
Is that connecting chain a known weak link? Do the OEM chains have a master link? if so, that's where it broke because there is no master link anymore (either flew through the top or is down in the motor. Have you seen tensioners fail?allowing the chain to jump the sprockets.
I was going to try to just redo the head but I am worried about pieces of the chain etc having gone down the oil passages, which makes me thing I should drop the pan, can that be done with the engine in the car?
Any thoughts, ideas are appreciated.
Jamie
rotaryrex7 is offline   Reply With Quote
Old 08-10-2005, 11:46 PM   #2 (permalink)
nobrakese36's Avatar
nobrakese36 is on a distinguished road
Send a message via Yahoo to nobrakese36
hello hope this helps, i went through the Bentley manual and it said nothing about a master link, so the chain is one piece, also you were worried about the pieces of chain falling in the oil pan, well to remove and install the timing chain the Bentley manual says the oil pan needs to be removed, that sucks but it had to be done anyway, areason the chain broke was probably due to wear and extreme tension, this problem plagued the older m3's and m5's, well good luck
nobrakese36 is offline   Reply With Quote
timing chain tensioner? eclipsevrl 3-Series (E36) 4 01-05-2006 05:33 PM
Timing Chain Tensioner Swap, Is It Possible? victorgallas 3-Series (E36) 0 03-29-2005 02:25 PM
Vanos Or Timing Chain Problem? liquidtiger720 5-Series (E12,E28, E34, E39, E60) 0 12-11-2004 08:59 PM
Timing Chain On My '94 325i Turbotec 3-Series (E36) 2 10-24-2004 05:10 PM
Timing Chain Cover Removal (e36 M3) Jams6502 M-Series (M1, M3, M5, M6) 3 10-06-2004 04:35 PM
