Brembo Rotors - BMW Forum - BimmerWerkz.com
post #1 of 27 (permalink) Old 06-21-2005, 10:56 AM Thread Starter
theironm0nk is an unknown quantity at this point
Which one should I go with?
theironm0nk is offline
post #2 of 27 (permalink) Old 06-21-2005, 11:32 AM
Unless you are in to profiling the solid rotors work the best and are easier on brake pads.
Bear is offline
post #3 of 27 (permalink) Old 06-21-2005, 11:38 AM
RexKing86's Avatar
Quoted: 1 Post(s)
RexKing86 is an unknown quantity at this point
Send a message via AIM to RexKing86
Im not a brake expert, but ive heard that slotted wear your pads the fastest, the slots actually shear down the pad. If you want both, some companies make a slotted abd cross-drilled rotor. Im getting new brakes soon, and I think im going to go with just cross-drilled, not because i break hard a lot... but because they look cool!
RexKing86 is offline
post #4 of 27 (permalink) Old 06-21-2005, 01:33 PM
jshearer's Avatar
jshearer is an unknown quantity at this point
[snapback]355493[/snapback]
I believe it is the opposite. The Cross drilled will wear your pads faster than the slotted. Both will improve braking though.
<a href="http://imageshack.us"><img src="http://img217.imageshack.us/img217/3466/quicksignature20te.jpg" border="0" width="600" alt="Image Hosted by ImageShack.us" /></a>
jshearer is offline
post #5 of 27 (permalink) Old 06-21-2005, 02:43 PM
Science Roolz!
SHAHAB323IS is a name known to all SHAHAB323IS is a name known to all SHAHAB323IS is a name known to all SHAHAB323IS is a name known to all SHAHAB323IS is a name known to all SHAHAB323IS is a name known to all
Originally posted by jshearer+Jun 21 2005, 11:33 AM--><div class='quotetop'>QUOTE(jshearer @ Jun 21 2005, 11:33 AM)</div><div class='quotemain'><!--QuoteBegin-RexKing86@Jun 21 2005, 10:38 AM
[snapback]355526[/snapback]
[/b][/quote]
true
2011 Mazda2
1990 Mazda Miata
SHAHAB323IS is offline
post #6 of 27 (permalink) Old 06-21-2005, 03:15 PM Thread Starter
I drive daily through areas where I travel around 80-90mph and atleast 45 for most of my travel.
I'm thinking of buying hawk performance HPS brakes front and rear since I cant find any rear bosch brakes.
post #7 of 27 (permalink) Old 06-21-2005, 03:59 PM
A lot of contrversy on this issue but the NASCAR guys use solid rotors and they brake prety hard at Bristol, and Richmond and the PORSCHE cups guys take their cross drilled rotrs off to race. Just a litle food for thought.
Bear is offline
post #8 of 27 (permalink) Old 06-21-2005, 04:24 PM
///M Power's Avatar
Quoted: 2 Post(s)
///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute
I thought slotted wore it faster than cross drilled??? Although slotted are supposed to disperse heat better. Maybe I have it backwards but thats what I believe i learned a logn time ago. I've never upgraded rotors so i never really put a lot of research time into it.
///M Power is offline
post #9 of 27 (permalink) Old 06-21-2005, 05:14 PM
vincentwashere is an unknown quantity at this point
Send a message via AIM to vincentwashere
slotted rotors and GOOD brake pads depending on how u drive. my friend caught his greenstuff brakepads on fire/(well all we saw was the smoke) even with brembo slotted rotors. when we were doing a heavy breakage canyon run.
<img src='http://pic15.picturetrail.com/VOL615/2358567/4641837/67358906.jpg' border='0' alt='user posted image' />
vincentwashere is offline
post #10 of 27 (permalink) Old 06-21-2005, 05:40 PM
jetblack325
Guest
Posts: n/a
Quoted: Post(s)
Cross drilled rotors do not help you to stop any quicker they simply disperse heat more efficiently.
post #11 of 27 (permalink) Old 06-21-2005, 10:02 PM Thread Starter
So should I go with brembo solid rotors or what is the wear and tear on the brakes significant?
post #12 of 27 (permalink) Old 06-21-2005, 10:08 PM
Jrf786 is an unknown quantity at this point
Slotted rotors take peices of your brake pad off to give it a clean surface everytime you use your brakes. They also help with heat dispersion. But yeah, they do eat your brakes. Cross drilled do the same but to a lesser extent. Although be careful as cross drilled have been known to crack.. I'm going with cross drilled, I dont really need them except for the rare saturday when I rip the piss outta my car, but other than that, they just look nice.
Jrf786 is offline
post #13 of 27 (permalink) Old 06-21-2005, 10:22 PM Thread Starter
well how often do drilled crack because then its more cost efficent to have to replace brake pads more often then replacing rotors. Especially since I'm getting 4 rotors. But thinking about it I do pound on my car alot especially since I go from traveling 70-80mph and have to slow down to a stop with in 150 feet and have to be able to deal with stop and go traffic right after.
post #14 of 27 (permalink) Old 06-21-2005, 11:35 PM
if ur braking consitently like autocross go with slotted. if no just stay with solid and get good pads. also if ur doing 70-80 hard braking. i would get some good ss-lines too.
post #15 of 27 (permalink) Old 06-22-2005, 01:13 AM Thread Starter
Thanks for the input I have chosen to order the Brembo slot rotors and hawk performance HPS brakes.
Also is it worth it to buy SSB lines? How difficult is it to replace those.
: Kind of funny that I have 5 years of Automotive mechanical experience. DOing brake and rotor changes to tune ups to tire and rims exchange and balance to V-6 automatic to V-8 manual conversions of cars and I have never changed brake lines.
Story of my car : recently it was crashed by hard time braking and a suden stall jumping the car foward. only asthetic damage hood and nose. The cause needed a tune up and the brake pads were so worn the rivets in the pads cut into the rotors yet they some how past inspection.....
Brake rotors a must change?? Z0Sicks 3-Series (E46, E90) 3 11-06-2005 02:23 PM
Brakes Front Rotors And All Pads camnipotent 3-Series (E36) 4 07-26-2005 08:29 PM
Brembo time! Any recommendations? NeverLeaned 3-Series (E36) 8 09-21-2004 11:51 PM
Bendix Rotors Any Good? HoFF 3-Series (E21, E30) 5 05-28-2004 06:13 PM
Brake and Rotors roguesniper1 3-Series (E36) 11 05-14-2004 07:45 PM
