| what car do you have first of all. secondly what type of pads did you put on. just so you know lots of aftermarket upgraded pads squeek, its very common only because they are so performance oriented the blend they use has a tendency to squeel. id suggest taking the car up to about 40 and braking hard. see if you cant burnish the pads a bit better.
__________________ |
