Brakes - BMW Forum - BimmerWerkz.com
post #1 of 21 (permalink) Old 05-19-2005, 11:11 PM Thread Starter
Steinkek is an unknown quantity at this point
I know that i dont have anti-lock brakes on my car because the other day i was in a gravel drive way and slamed on my brakes and i just slid. Do any of the E36s come with anti-lock brakes?
Steinkek is offline
post #2 of 21 (permalink) Old 05-20-2005, 01:21 AM
LivinFast67's Avatar
LivinFast67 is an unknown quantity at this point
Send a message via AIM to LivinFast67
um. anti lock brakes don't work too well in gravel. there on but they can't get traction either way so you slide anyway ( i rolled my landrover with anti lock brakes off a ciff cuz it slid with abs) do a hard brake check on a clear road. and it'll tell you if you have abs. You should
<img src='http://n00106.myspace.com/00106/13/45/106195431_l.jpg' border='0' alt='user posted image' />
Breyton Inspiration 17&quot;x8.5&quot;, dde plus, euro elispoids, clear front markers/rear light's, k&amp;n ram cold air intake, Clarion Deck, 8&quot; sub tube
Member:3 pedal club
Member: 10+ years club
Member: Ran from a cop and got away club
LivinFast67 is offline
post #3 of 21 (permalink) Old 05-20-2005, 02:50 AM
ex owner/admin
Furious's Avatar
Quoted: 1 Post(s)
your car should have abs brakes. if it doenst work than it must be disabled somehow
Furious is offline
post #4 of 21 (permalink) Old 05-20-2005, 12:08 PM
pcy
pcy is an unknown quantity at this point
[snapback]346267[/snapback]
When you turn on the ignition, look closely on the cluster, do you see the ABS light doing a self-test (i.e., turning on for a second or two and then turning off by iteself) ? If you see the ABS light turning on and off during the startup, ABS is fine. Like others have suggested, drive in a parking lot and brake hard; if the ABS is working you will fee it by the brake pedal.
pcy
pcy is offline
post #5 of 21 (permalink) Old 05-20-2005, 12:23 PM
7th Gear (SMG)
You should also hear it - a low thrumming noise.
1998 BMW e36 M3 Sedan
2003 MINI Cooper
4evrwyntr is offline
post #6 of 21 (permalink) Old 05-20-2005, 12:56 PM
ILiveToRide is an unknown quantity at this point
[snapback]346292[/snapback]
Then they shouldn't work in the wet or on snow either :P
And that is when you really need it!
Mine works on ice.
<img src='
1994 Arcticsilber M3, 286hp, 18&quot; AC Schnitzer wheels.
ILiveToRide is offline
post #7 of 21 (permalink) Old 05-20-2005, 03:14 PM
thekid's Avatar
thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute
Actually, ABS is horrible on gravel, however, great in the wet, snow and ice. Here is why. The only way to stop quickly in gravel is to lock the wheels up. It then creates a wall of gravel infront of the car and digs down to whatever is underneath the gravel. If you will notice, off road vehicles do not have ABS. With ABS the car stops over a much longer distance, because the car keeps releasing the brakes because the wheels lock up. So if you ever plan on off roading, get rid of ABS.
thekid is offline
post #8 of 21 (permalink) Old 05-20-2005, 09:53 PM
Didn't think about that loose gravel, gravel roads aren't really loose here most of the time. Sorry.
But the point of ABS isn't to cut the stopping distance, it's there for you to be able to control/steer the car during hard braking.
Racing (road course) cars don't use ABS either.
<img src='
post #9 of 21 (permalink) Old 05-21-2005, 12:00 AM
WarNox's Avatar
the point of abs is to stop the car quicker!!!! and also to give u more control. The theory about gravel makes sense yeah but shouldnt the same theory apply to snow then too, when u break you would build a wall of snow infront of you which will make you stop quicker too as it will be harder for the car to slide further forward!? thts just me thinking logically though, dunno if im right or not but abs do stop you quicker. racing cars don't need it as they dont exactly need to skid to a full stop as fast as they can!?
<img src='
WarNox is offline
post #10 of 21 (permalink) Old 05-21-2005, 10:47 AM
7th Gear (SMG)
[snapback]346573[/snapback]
At first thought, yes. The properties of snow (water) and gravel (rock, usually limestone of some sort or granite or some kind of mixture). Consider that snow when compressed becomes ice, also compression causes heat, which will melt snow and form water. If you compress snow quickly enough, that means you'll get ice covered water in front of your tires. Compressing rock will melt it, yes, heating rock will melt it yes, but at MUCH higher compression rates and heating rates (obviously).
Now, a lump of bumpy rock will stop your car much faster than a lump of water covered ice.
Just to let you know from the science viewpoint.
You know, just from me and redline's argument, I'm going to appoint myself head of scientific reasoning on this board. Heh.
2003 MINI Cooper
post #11 of 21 (permalink) Old 05-21-2005, 12:06 PM
Think about that, the physics behind it, and explain it.
<img src='
post #12 of 21 (permalink) Old 05-21-2005, 01:47 PM
thekid's Avatar
Originally posted by ILiveToRide+May 21 2005, 10:06 AM--><div class='quotetop'>QUOTE(ILiveToRide @ May 21 2005, 10:06 AM)</div><div class='quotemain'><!--QuoteBegin-WarNox@May 21 2005, 06:00 AM
[snapback]346660[/snapback]
[/b][/quote]
The point of ABS is to stop the car quicker with the brake fully deppressed. Considering the skill of most drivers on the road. If something jumps out infront of thier car like a person, dog, cat or light pole, they will slam on the brakes whether it is dry or pouring down rain. People panic when their car doesn't stop and press down on the brake more. Only experianced drivers will modulate the brake pedal in a car without ABS. Thereby ABS stops the car quicker for an inexperainced or typical driver quicker. However, a skilled driver without ABS will be able to stop the car quicker everytime, because the driver will be able to use maxium braking force for the conditions that the driver is in. So for an experianced driver ABS doesn't evn play into the equation because the experianced driver would never let it activate by over braking for the conditions that he is in.
thekid is offline
post #13 of 21 (permalink) Old 05-21-2005, 04:17 PM
Originally posted by thekid+May 21 2005, 07:47 PM--><div class='quotetop'>QUOTE(thekid @ May 21 2005, 07:47 PM)</div><div class='quotemain'>
[snapback]346674[/snapback]
[/b][/quote]
That is basically what I said earlier, even though I didn't put into that many words.
And I stand by that the reason ABS was developed was so that you could correct/avoid the slide you'd (usually) get under hard braking when trying to avoid an object. Especially when you panic and slam the brakes, but still try to steer.
But this is like arguing which came first, the hen or the egg?
Not sure I think you're entirely right about that last bit.
<img src='
post #14 of 21 (permalink) Old 05-21-2005, 05:43 PM
thekid's Avatar
About the experianced driver? Then how come race cars do not have ABS? Once you get the feel for the car the ABS should never kick in. The ABS in my car has kicked in once. It only kicked in because I was being stupid and trying to make a buddy who was beating me in a race miss a turn so he would have to go down and find a place to turn around. But any way, experianced drivers do not need ABS for anything. Period.
thekid is offline
post #15 of 21 (permalink) Old 05-21-2005, 06:04 PM
RedlinedRU's Avatar
RedlinedRU is an unknown quantity at this point
Send a message via AIM to RedlinedRU
ABS is made to keep the wheels from locking up because if the wheels are locked up, you can't steer the car/truck/whatever. They don't stop the car faster in the dry, sometimes though in the wet they will. The point is that you can hit the brakes hard with ABS and still turn the car to swerve out of the way.
<span style='color:green'>
AMG can't build an NA engine that can compete with M engines, so they stick in a supercharger and say their cars are faster. BMW could simply do the same, but they don't out of principle.</span>
RedlinedRU is offline
Had To Replace Brakes At 15,000 Miles Now At 25,00 eburatti 3-Series (E46, E90) 15 10-25-2005 11:36 AM
Squeeling New Brakes Ljk619 3-Series (E46, E90) 6 07-08-2005 02:31 PM
330xi Highway Miles, How Long Rear Brakes Last clydesdale 3-Series (E46, E90) 3 02-27-2005 04:39 AM
Steering Shaking With And Without Hot Brakes zanick 3-Series (E46, E90) 3 10-26-2004 12:02 PM
do your brakes squeak? GnarlyCow 3-Series (E46, E90) 12 09-22-2004 09:03 PM
