Brake Pads And Rattling - BMW Forum - BimmerWerkz.com
Old 12-27-2004, 06:21 AM   #1 (permalink)
mmclaren is an unknown quantity at this point
from wat i have red and searched for i need new brake pads
I have a rattling at the front wheel "i think" when i go over bumps gives a metal rattling sound
Also even though my brake pads are fairly knew they seem to squeel...
any ideas on this problem??
mmclaren is offline   Reply With Quote
Old 12-27-2004, 06:40 AM   #2 (permalink)
Fadec40 is an unknown quantity at this point
Pull the front wheels off and inspect the whole assemblies. Anything that is rattling might be easy to find with tthe car jacked up. It is possible the clips that keep the brake pads from rattling might be the problem.
I am leaning to something other than the brake pads making the rattling noise.
Fadec40 is offline   Reply With Quote
Old 12-27-2004, 12:10 PM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
If you need new brake pads.. I'd say replace those... and make sure everything is sound.. and in good tight order.. and drive it... if it still does it.. take it off.. and search around...
It should be obvious once you get the wheel off and push around..
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 12-27-2004, 09:49 PM   #4 (permalink)
it is the brake pad, isnt in secure, moves around, going to replace them, any brands i should be looking for, or any certain type
330Ci Rear Rattling noise???? HELP! sprite330ci 3-Series (E46, E90) 0 10-30-2005 05:46 PM
High Pitched Rattling In Front Wheel Well Cannon00000 3-Series (E36) 2 05-06-2005 11:21 AM
