brake pads - BMW Forum - BimmerWerkz.com
Old 12-14-2005, 06:16 PM   #1 (permalink)
taylor is an unknown quantity at this point
brake pads
Do I need a sensor for brake pads? I'm having it done at a local shop, not the stealership. Thanks
taylor is offline   Reply With Quote
Old 12-14-2005, 08:45 PM   #2 (permalink)
BImmerN2B's Avatar
BImmerN2B is an unknown quantity at this point
Yes, only one for the front and one for the back. so 1+1=2 that is how much you will need brother.
BImmerN2B is offline   Reply With Quote
Old 12-14-2005, 09:22 PM   #3 (permalink)
bimmerboy328i's Avatar
bimmerboy328i is an unknown quantity at this point
Send a message via AIM to bimmerboy328i
Yes, they are good to have.
- 97 M52 Beast - Vortech V-1 Supercharger Setup - Dinan Software - 28.8lb Injectors - 9psi - ZKW's - OEM Clears - DoubleSpoke II's - OEM M3 Spoiler - OEM M3 Front Bumper - 20% Tint - CCFL Angel Eyes - 6K Xtec HIDs in ZKWs - 6k H1 based D2S HID's in Foglights - Bilstein Sport Shocks - Eibach Sportline Springs - Cosmos Racing CAI - M50 Manifold Swap - UUC Motorwerks SystemU Exhaust - Fan Delete - 3.15 LSD -
bimmerboy328i is offline   Reply With Quote
Old 12-15-2005, 11:32 AM   #4 (permalink)
7th Gear (SMG)
You know, I didn't know that other vehicles don't have this simple necessity until a few weeks ago...
1998 BMW e36 M3 Sedan
2003 MINI Cooper
Old 12-16-2005, 05:59 AM   #5 (permalink)
What if you don't put one in the new pads? Will the brake sensor light stay on?
Old 12-16-2005, 10:27 AM   #6 (permalink)
Storamin's Avatar
Storamin is an unknown quantity at this point
If the brake sensor light has come on, you need new sensors. If it doesn't come on and you replace the brakes, you can re use the old ones. The brake sensor will stay on until you replace it.
Storamin is offline   Reply With Quote
Old 12-16-2005, 10:54 AM   #7 (permalink)
rej487's Avatar
rej487 has a spectacular aura aboutrej487 has a spectacular aura aboutrej487 has a spectacular aura about
Send a message via AIM to rej487
Now what kinda sense does that make? OH YEAHHHH... they don't call them the stealership for nothing! :lol:
1993 BMW 325I - Alpina White
rej487 is offline   Reply With Quote
Old 12-16-2005, 01:45 PM   #8 (permalink)
Storamin's Avatar
It's actually a pretty neat design. What happens when the brake pad starts to be used up, the sensor will get chewed up (I believe). So when it comes on, the sensor has been chewed up and you should replace it with a new one. It beats not having a sensor...
Old 12-16-2005, 02:20 PM   #9 (permalink)
rej487's Avatar
I never knew the sensor actually deteriorated as well... interesting...
Old 12-16-2005, 03:57 PM   #10 (permalink)
7th Gear (SMG)
I was always under the impression that you should ALWAYS replace the sensor... which would be explained by a chewed up sensor.
2003 MINI Cooper
Old 12-16-2005, 05:49 PM   #11 (permalink)
rej487's Avatar
Well, my bimmer is my first and I've never had to change the breaks. Bought my car from a grandma with 76,000 (1993) and they are still thick as can be
Old 12-16-2005, 05:53 PM   #12 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
You SHOULD reaplce the sensor. Somehow on my e34 I got away with not changign the sensor out of prue stupidity. I forgot to order the sensors and was lazy and just installed the new pads. Soemhow the sesor did not stay lit and was in decent shape apparently.
Old 12-17-2005, 12:58 AM   #13 (permalink)
tomctx's Avatar
The sensor has a plastic coating on it. When the pads get thin enough, the rotor rubs off the plastic coating. The inside is metal, which makes contact with the rotor, which lights the "wear" light. If it is not too chewed up, you can reuse it. However, if you're not comfortable with reusing, they are cheap to replace.
Performance Brake Pads topless_328 3-Series (E36) 4 11-24-2005 12:08 PM
Brake Pads ///M Power 5-Series (E12,E28, E34, E39, E60) 20 08-12-2005 09:26 PM
Aftermarket Brake Pads. HardStep Product Reviews 2 01-11-2005 11:44 AM
Need New Brake Pads And Rotors And Have Some ?'s elbee 3-Series (E46, E90) 4 12-18-2004 05:25 PM
