Brake Pads - BMW Forum - BimmerWerkz.com
Old 11-27-2004, 10:39 PM   #1 (permalink)
catalyst. is an unknown quantity at this point
Send a message via AIM to catalyst.
im replacing my brakes.. what pads should i use?
i want something with less dust than the oem ones + performance and longevity
also... do i have to replace the brake pad wear sensor everytime i put new pads in?
catalyst. is offline   Reply With Quote
Old 11-27-2004, 11:14 PM   #2 (permalink)
Threadkiller
bitcore's Avatar
[snapback]238621[/snapback]
Yes, for the light to function normally you need to... but you dont HAVE to, I guess you could just twist the wires together to make the light turn off. It's a good idea to replace it because you wont really have a good idea how much brake is left until you start grinding the rotors and it makes that awful noise...
Old 11-27-2004, 11:39 PM   #3 (permalink)
WOT in Reverse
jllphan's Avatar
Originally posted by catalyst.@Nov 27 2004, 10:39 PM
im replacing my brakes.. what pads should i use?* i want something with less dust than the oem ones + performance and longevity
Recomended by Furious, I tried a set of EBC Green Stuff pads. They take a little "brake" in time, but now have unbelievable stopping power. I do a variety of driving, and they meet every need. As they are Kevlar, they also are nearly dustless! Highly recomended.
You tell me. Has your brake wear sensor light turned on? If so, you will need to replace one or both (probably front). I bought front and rear, just in case. I didn't need to change the rear sensor, so I swapped it for an oil filter
Old 11-27-2004, 11:51 PM   #4 (permalink)
gahh those are expensive as hell.. theyre probably worth it though.
Old 11-28-2004, 01:39 AM   #5 (permalink)
_1634_ is an unknown quantity at this point
I am avery satisfied with my Hawk HPS pads. As for the dust aspect, my rear wheels dont have much dust on them (with the "smooth"/stock/OEM rotors) but my front rotors are slotted so they have brake dust on them from the slots. mine were $160 front and back at bimmerworld.com
As for the sensors, optimally, you should change them every time whether or not your brake light has illuminated on your dashboard. But if the light has not gone on, your pads have not worn down enough for the sensor to contact the bare rotor through the pad, if your on a tight budget id say skip the sensors if the light hasnt came on...
<span style='font-family:Arial'>1994 BMW 325is // White // 5 Speed
Slotted Rotors // Hawk HPS Pads <span style='color:blue'>//</span><span style='color:red'>/</span>Motorsport Shifter // De-Baffled Airbox</span>
_1634_ is offline   Reply With Quote
Old 11-28-2004, 10:13 AM   #6 (permalink)
Threadkiller
bitcore's Avatar
I say you'll be perfectly fine re-using them if the light hasn't come on if they havn't been worn too much.
Old 11-28-2004, 10:44 AM   #7 (permalink)
quality
Delmarco's Avatar
Originally posted by jllphan+Nov 27 2004, 11:39 PM--><div class='quotetop'>QUOTE(jllphan @ Nov 27 2004, 11:39 PM)</div><div class='quotemain'><!--QuoteBegin-catalyst.@Nov 27 2004, 10:39 PM
[snapback]238663[/snapback]
[/b][/quote]
I was looking at the green stuff...but the tirerack reviews say that they are LOUD even when breaking at tslow speeds...I'm assuming since we drive the same cars...I'd rather take your spin on it jllphan...what do you say?
Old 11-28-2004, 06:28 PM   #8 (permalink)
I love my PBR metal-masters. No dust, stop great, not noisey, and only about $35 for the front set. They are a great set of pads, especially if your car will not see track time.
Old 11-28-2004, 10:00 PM   #9 (permalink)
WOT in Reverse
jllphan's Avatar
No Del, they aren't loud.
Yes PBR metal masters are good, but they can wear out your rotors pretty easily. I almost bought them, but didn't plan on replacing my rotors this time around.
And no, you don't have to replace your sensor unless it is worn out. It's pretty easy to tell if the sensor has worn down to the indicator by looking at it.
Old 11-29-2004, 01:26 PM   #10 (permalink)
Threadkiller
bitcore's Avatar
What about the brake noise, sometimes pads are just plain loud for long periods of time, occasionally quieting down and then becoming loud again, or just loud for their entire little lives.
What about this brake paste stuff, does it just glue the pad to the brake cylender and prevent the high pitched vibration by the addition of mass?
Brake Pads ///M Power 5-Series (E12,E28, E34, E39, E60) 20 08-12-2005 09:26 PM
Aftermarket Brake Pads. HardStep Product Reviews 2 01-11-2005 11:44 AM
Need New Brake Pads And Rotors And Have Some ?'s elbee 3-Series (E46, E90) 4 12-18-2004 05:25 PM
Changed my brake pads BlantonG13 3-Series (E36) 17 08-04-2004 09:27 AM
