Brake pad thickness? - BMW Forum - BimmerWerkz.com
Old 08-20-2004, 12:44 PM   #1 (permalink)
Laker is an unknown quantity at this point
My brake pad sensor went off, so how much life is left on the pads in %? Example 30% 1994 325. Thanks
Laker is offline   Reply With Quote
Old 08-20-2004, 12:49 PM   #2 (permalink)
BMWBeauty416's Avatar
Car: '00 M-B CLK430 Cabriolet
BMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to all
Send a message via AIM to BMWBeauty416 Send a message via MSN to BMWBeauty416 Send a message via Yahoo to BMWBeauty416
when mine went off I had about 20-25% but I rode on them for about 2 weeks after the sensor went off
don't know if that helps but hey hopefuly
~*Teg*~
BMWBeauty416 is offline   Reply With Quote
Old 08-20-2004, 01:40 PM   #3 (permalink)
Threadkiller
bitcore's Avatar
I'd either go ahead and replace the brakes or at least take the worn sensor out of the brake pad, it will cut a considerable groove in your rotor and it will take about 2-3 weeks for that groove to even out after you get new pads. This means less braking power for 2-3 weeks after you get new pads.
Old 08-20-2004, 08:41 PM   #4 (permalink)
_1634_ is an unknown quantity at this point
Best thing to do is:
1. Replace Brake Pads
2. Replace Brake pad sensors
3. Replace/Flush brake fluid
4. Check rotor thickness.
check out:
E36 DIY
for more information.
Ive seen the brake sensors for the E36 at pelicanparts.com
$12 each i think. Some places reccomend to replace them even if the brake light doesnt go on. My car was just inspected at the dealership and i supposely have 5% on my rear brakes but the sensor is not on, so im assuming its broken or the dealership is full of shit. They wanted $300 for a brake job.
I just bought some Hawk HPS brake pads from bimmerworld.com (best price i could find) for my 94 325is.
<span style='font-family:Arial'>1994 BMW 325is // White // 5 Speed
Slotted Rotors // Hawk HPS Pads <span style='color:blue'>//</span><span style='color:red'>/</span>Motorsport Shifter // De-Baffled Airbox</span>
_1634_ is offline   Reply With Quote
Old 08-20-2004, 09:13 PM   #5 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Of course you'd want to check the rotor thickness... before you do all of that.. just so if you need new rotors.. you can get them installed.. and noy be doing work twice.
1997 E36 M3 1990 E30 325i
Old 08-21-2004, 12:01 AM   #6 (permalink)
My bad. ghead
yes, check the rotor thickness first.
The minimum thickness for E36 rear rotors are as follows:
Solid:* * * * * * 8.4mm
Vented:* * * * 17.4mm
M3 Vented:* 18.4mm
http://www.smithnet.ca/bmwclub_faqs/e36_re...rakes/start.htm
Re: What's the minimum rotor thickness for a 328i?
According to the Bentley: 20.4mm (.803 in.) and 8.4mm (.331 in.) rear.
http://bimmer.roadfly.org/bmw/forums/e36/4881141-2.html
Old 08-23-2004, 01:26 PM   #7 (permalink)
Thanks for the replys, I'm trying to get the dealer to pay for the brakes. I put 200 miles on car and the sensor went off, dealer inspection report said I had 70% left.
Old 08-23-2004, 11:03 PM   #8 (permalink)
They will probably just say its a faulty sensor, or that your driving is too "spirited" :wink
bmw stealer-ship bastards!
Parking brake not releasing GnarlyCow 3-Series (E46, E90) 13 07-29-2004 03:39 AM
