| there is no way unfortunately either you get the brake sensor replaced or it will continue to show, same with the abs light, its possible you have an issue with a speed sensor, if you can find a good european mechanic you might be able to save a few bucks or tackle the issue yourself there is a DIY on brake jobs in the FAQ forum however for the speedsensor or whatever is causing your ABS issue you will need to get a scan to tell you what it is. so dealer it is.
__________________ |
