Brake Line &abs Lights
1K views 1 reply 2 participants last post by  Furious
#1 ·
CAN ANYBODY TELL ME HOW TO CLEAR BRAKE LINE & ABS LIGHTS ON MY 97 328 IC WITHOUT GOING TO THE DEALER?I GUESS IT NEEDS A BRAKE JOB BUT I DON'T KNOW HOW TO CLEAR IT(BRAKE LINE LIGHT) AFTER THAT.
I APPRECIATE ANY HELP:confused:
#2 ·
there is no way unfortunately either you get the brake sensor replaced or it will continue to show, same with the abs light, its possible you have an issue with a speed sensor, if you can find a good european mechanic you might be able to save a few bucks or tackle the issue yourself there is a DIY on brake jobs in the FAQ forum however for the speedsensor or whatever is causing your ABS issue you will need to get a scan to tell you what it is. so dealer it is.
