I have a friend who has a 1997 318Ti. The brake lights are staying on all the time. I checked the fuses and they all seem ok. Any ideas on what it might be? Thanks.
I don't know 318's, but my guess would be to look at replacing the brake light switch, which is a common problem on the e36's. I hear there is a recall on these, so the dealer will do it for free .
The switch is located under the brake pedal. See the Pelican Parts website for a DIY to educate, then take it to the stealer for replacement. I didn;t know htere was a recall, so did it myself--pretty easy but a pain in the ass none-the-less. If you DIY get the BMW OE part--the aftermarket ones are supposed to be crap.
Hope that's the reason! :P
__________________ 98 328i, black/black, manual, canadian sport pkg, ECIS intake, koni sport adj's, dinan springs, oe/oem clears.
Considering: tms shark,M 17" wheels, larger sway bars.
Yea, that could be the brake lining sensor, meaning, it's time to change the brake pads..To make the light go away you will have to buy a new sensor as well..
Originally posted by ChuckLS2@Jan 6 2005, 10:24 PM I have a friend who has a 1997 318Ti. The brake lights are staying on all the time. I checked the fuses and they all seem ok. Any ideas on what it might be? Thanks.
Chuck
[snapback]265991[/snapback]
Are the actual brake lights on? OR the warning light on dashboard is on?
If the actual brake lights are continually on, my the brake switch is bad.
If the warning light on the dashboard is on, be specific and tell us which
indicator light is on (there are several... one for brake pad wear indicator,
brake fluid, abs, etc.)
Well I discovered something last night while checking the car. The brake lights only stay on when the headlights/parking lights are on. They work fine otherwise. I guess it may not be the brake light switch then. Any ideas?
That is very strange. The brake lights are on a totally diff. power curcuit from the tail lights. The only connection between them is that they share a common grounding connection, which may be a problem?
The other thing is there a 4 control modules after the brake light switch - ABS / Slip control / cruise / transmission control - not sure if one of those could be fault - although I doubt it.
Oh - so the brake lights turn on with the tail lights.
When you don't turn the lights on, do the brake lights work normally?
BMW, unlike all other cars have computerized brake sensors, if your friend has had his brakes changed and did not replace the sensors, the light will stay on until he changes the sensors, the sensors are usually only ~ $10 and (not sure about 318's) but you only need 2 sensors, one for the front, and one for the back.
__________________ VIEW MOD LIST & PICS
Originally Posted by Gregg
Originally posted by ChuckLS2+Jan 11 2005, 11:36 PM--><div class='quotetop'>QUOTE(ChuckLS2 @ Jan 11 2005, 11:36 PM)</div><div class='quotemain'><!--QuoteBegin-jkh2828@Jan 11 2005, 12:33 PM
[snapback]268894[/snapback]
Yes they work normally. As far as the sensors, not sure. She just bought the car a couple of months ago and has not done any brake work on it.
[snapback]269546[/snapback]
[/b][/quote]
Are you sure the taillights are Origional BMW Taillights? I baught a pair of aftermarket ones and they did the same thing.
__________________ BLACK 1995 BMW E36 325i
• <u>Dinan</u> Performance Software - SOLD!
• High-flow intake w/ Green Performance Filter
• 17 x 8.5 BMW Style 44 Rims
• <u>Pirelli</u> P6 tires 235/45/17
• M3 Spoiler
• Clear Tail Lights, Corners, and Side markers
• 20% Tint all around
• Sylvania Silverstar Bulbs
• <u>Alpine</u> 9831 MP3/CD Player
