Brake Lights Stay On - BMW Forum - BimmerWerkz.com
Old 12-05-2004, 02:25 PM   #1 (permalink)
bimmer_boy's Avatar
bimmer_boy is an unknown quantity at this point
Send a message via AIM to bimmer_boy
I think my brake lights stay on, as no light illuminates or dims as I hit the brake pedal! Anyone have a diagram of which light bulbs in your tail lights should be on while you're driving and which should be on while you're braking? That would help oh so much! Thanks...
PS Should the middle brake light in the rear window be on whenever the headlights are on or is it only supposed to illuminate while braking?
BLACK 1995 BMW E36 325i
• <u>Dinan</u> Performance Software - SOLD!
• High-flow intake w/ Green Performance Filter
• 17 x 8.5 BMW Style 44 Rims
• <u>Pirelli</u> P6 tires 235/45/17
• M3 Spoiler
• Clear Tail Lights, Corners, and Side markers
• 20% Tint all around
• Sylvania Silverstar Bulbs
• <u>Alpine</u> 9831 MP3/CD Player
bimmer_boy is offline   Reply With Quote
Old 12-05-2004, 03:09 PM   #2 (permalink)
[snapback]243984[/snapback]
My vote is for the stop light switch. Either the switch is bad or the brake pedal arm does not push the piston on the stop light switch in far enough to turn off the brake lights. Go under the dash and shim the piston on the brake light switch (or push the piston all the way in while your bud is watching the brake lights) and then check and see if the lights are out, if yes, then you can adjust the brake pedal arm back to fully seat the piston on the stop light switch. If she still does not go out I would replace the stop light switch.
Old 12-05-2004, 03:30 PM   #3 (permalink)
bimmer_boy's Avatar
Alright, but how many bulbs should light up when not braking and how many should be lit when braking? I need to know the normal scheme so I know which is correct, because my tail lights may be wired incorrectly. I have aftermarket clear crystal cut lights.
• M3 Spoiler
HELP - Brake, ABS, and DSC lights on Fangs 3-Series (E46, E90) 48 05-13-2011 01:39 PM
Brake Lights Stay On Nealdavis4 3-Series (E21, E30) 0 12-17-2004 01:21 AM
Brake Lights No Work Wtf?? daxsandman 3-Series (E21, E30) 2 12-07-2004 04:38 PM
Brake Lights Failure, Now. bkstaylor 3-Series (E36) 1 11-24-2004 09:45 AM
