| Have u tried testin the brake light switch??? (half way up the brake pedal, especially if its both lights that arent workin) See if its showing open circuit when it should be closed... Worked for me wen my lights packed up...
1 other thing, u may have dun this already, but check the 2 pins on the metal cap of the bulb. BMW genuine bulbs have offset pins, aftermarket 1's have symmetrical 1's and won't work correctly wen fitted...
Good Luck... |
