| Hot wires mean somethings shorted, find the problem and go back to the original size fuse before something catches on fire. Then you'll really be up a creek. See if you can get a circuit breaker to use in place of the fuse till the problem is found, they reset after cooling off.
Cosmos schwartz metalic Sparco strut brace factory X-brace 55w 6000k HID w/LED angel eyes smoked Lamin-X blacked out sidemarkers,tails and brakelights. DDM smoked corners and pedals. 35% tint all around, Prosport water temp and oil pressure gauges, Home Depot lip, M3 rear diffuser ASC-T delete. |
