brake light !!! helppppp - BMW Forum - BimmerWerkz.com
Old 12-27-2003, 08:26 PM   #1 (permalink)
p3rsian is an unknown quantity at this point
hey
i was driving and this lady told the that both my brake lights dont work !!! so i went to pepboys told a guy in the lot to check if my lights come on or not.
i replaced the bulbs and i came home. i closed the garage door so i can see if it comes on or not. i pressed the brake and nothing.. then after braking more it came on.. it seemed it wasnt coming on every time i brake..
after driving around it was still working. when i came home its not working anymore.. none of them
the fuse is ok.
what can it be ?
p3rsian is offline   Reply With Quote
Old 12-27-2003, 08:44 PM   #2 (permalink)
i was told that the switches (brake switch ) have alot of problems
can this be the cause ?
Old 12-28-2003, 12:32 PM   #3 (permalink)
bimmerfan620's Avatar
bimmerfan620 is an unknown quantity at this point
Send a message via AIM to bimmerfan620 Send a message via Yahoo to bimmerfan620
ye but when my brake circuit switch shows up in the check control, my brake lights still work... so maybe you have a fault somewhere along the wires or a short...
FOUNDER of the BMW-Forums Michigan Club
<span style='color:green'><a href='http://www.cardomain.com/memberpage/458339' target='_blank'> Car Domain UNFINISHED </a> </span>
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1078289877.jpg' border='0' alt='user posted image' />
bimmerfan620 is offline   Reply With Quote
Old 12-28-2003, 01:59 PM   #4 (permalink)
Defector
El Presidente's Avatar
i have/had this same problem. Mine are working now and havent gone out in awhile, but it is the switch on the pedal itself.
Old 12-28-2003, 04:56 PM   #5 (permalink)
EXtech's Avatar
You need a brake light switch. Also, you need to check the tail light assembly and the metal contacts in the sockets for burn spots.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 12-29-2003, 02:14 AM   #6 (permalink)
0p5
0p5 is an unknown quantity at this point
Send a message via AIM to 0p5
Yeah my stupid check control always pops up with "tail light" failure, but my taillights are fine. It's probably because I took out the fuses and put them back in and stupid BMW's have to be ritsy and need a BMW dealership to reset something. Just like when you get an oil change or brake pads replaced....*sighs*...stupid ritzy bastards.
<img src='http://members.cox.net/m4yorthis/BMW6(remade).jpg' border='0' alt='user posted image' />
0p5 is offline   Reply With Quote
Old 12-29-2003, 06:06 AM   #7 (permalink)
the///man is an unknown quantity at this point
i had the message apear on the ECU but the tail lights were fine. so i went to the dealer and bought the little part and installed it. now everythings fine and i dont get the message anymore. i dont think you have the same problem though, you could try that but idk if that will fix your problem. do you have aftermarket tail lights? if you do there might be a faulty connection somewhere.
the///man is offline   Reply With Quote
Brake Light Circuit Warning (again) Stamey 3-Series (E21, E30) 11 03-05-2005 07:05 PM
I test drive this Yesterday ! challe 3-Series (E36) 35 04-26-2004 11:17 PM
After tail-light upgrade, left brake light is gone mostwired 3-Series (E36) 3 11-26-2003 05:13 PM
