Brake light failure - BMW Forum - BimmerWerkz.com
Old 05-27-2009, 01:46 PM   #1 (permalink)
328ic98's Avatar
Car: 1998 BMW 328 Ic Cabriolet
328ic98 is on a distinguished road
Brake light failure
I have researched this, and this what it seams everyone says- Change the switch under the dash. The closest BMW dealer is a 2 hour drive. Should i put a "jobber" switch in from napa? Here is a recap- My computer has been saying brake light circuit- all were fine- then it said it again now, and I have NO brake lights at all! I checked the harnass that is faulty in the back, and it is perfect. The terminals look good, the bulbs are good, and the same. All 3 ( 2 plus my centre) are dead! It is a 98 328 I Convertible. So the question is - does this seam like a switch issue, and should i get a jobber? Thanks!
328ic98 is offline   Reply With Quote
Old 05-27-2009, 02:00 PM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Have you removed the harness tape where it hinges at the trunk hinge? you may find a broken wire, common problem.
Old 05-27-2009, 02:12 PM   #3 (permalink)
328ic98's Avatar
everything looks fine on the wiring end. i guess i'll take my chances on a switch...
Old 05-27-2009, 06:32 PM   #4 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
I changed mine after checking the trunk harness, & that fixed it.......
Here is a link to help you along......
brakeswitch.page
note: also check each brake light socket for burnt contacts.....
johnny,
Old 05-28-2009, 07:56 AM   #5 (permalink)
328ic98's Avatar
I did check the terminals and they look really clean, and my taillights work fine. At first only my drivers side brake light stopped, and now ihave NOTHING! I could not even get a jobber switch here in town, no one had one- or could not order one from suppliers...That is what you get for being in the country where everyone drives pick-ups!I ordered the switch from a BMW dealership in Toronto, should be here tomorrow delivered and all for about $40 Canadian. Hope this fixes the problem! Should i disconect the battery for this install to reset the computer?
Old 05-28-2009, 08:38 AM   #6 (permalink)
marti5's Avatar
Yes I would disconnect the battery, just the + will be fine, but make sure you have the radio code just in case.
Old 06-04-2009, 12:07 PM   #7 (permalink)
fabcal's Avatar
Car: 1995 BMW 325is
fabcal is on a distinguished road
It's the brake switch under the dash, I had the same problem. it's really easy to change, 10 minutes max, here's the link, go check it out: Pelican Technical Article: BMW Brake Switch Replacement
fabcal is offline   Reply With Quote
Old 06-06-2009, 10:16 AM   #8 (permalink)
328ic98's Avatar
Thanks folks, it was indeed the switch. The teminals are actually looking a little used, I am getting light failure on one side from time to time...Something to look into! Thanks my brothers!
tail light and brake light failure smacker 3-Series (E36) 4 10-23-2008 10:44 PM
Brake Light Circuit And Tail Light Failure 325is1994 3-Series (E36) 7 08-05-2008 12:00 PM
Brake Light Failure bimmer3214 3-Series (E36) 10 09-18-2005 04:33 PM
Brake Light Circuit Failure Ding 3-Series (E36) 8 09-16-2004 05:24 PM
Rear brake light failure bitcore 3-Series (E36) 7 08-21-2004 02:02 PM
