Brake Light Circut - BMW Forum - BimmerWerkz.com
Old 05-21-2004, 07:30 PM   #1 (permalink)
tallguy is an unknown quantity at this point
I keep getting the trouble" Brake Light Circut" on my car. After a while , 2 -3 hours it changes to "Brake light Failure". I have had the car to two service centers and have been assured it is fixed three times only to have"Brake Light Circut" come back on again.
Any ideas on what could be wrong???
tallguy is offline   Reply With Quote
Old 05-21-2004, 08:14 PM   #2 (permalink)
nack17 is an unknown quantity at this point
your not alone! I have the same problem but have not had a chance to figure it out yet.
nack17 is offline   Reply With Quote
Old 05-21-2004, 09:47 PM   #3 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile
Send a message via ICQ to jrhaile Send a message via AIM to jrhaile Send a message via MSN to jrhaile
use the search feature... over 100 threads probably about this problem
jrhaile is offline   Reply With Quote
Old 05-21-2004, 10:03 PM   #4 (permalink)
skawful's Avatar
skawful is an unknown quantity at this point
Send a message via AIM to skawful
i had the SAME thing:
what i did:
went to autozone
got me self a couple of brake light bulbs
threw em in there
warnings stopped...
also the warning came on before one of my lights went out... but replacing them both fixed the problems
<img src='http://img259.imageshack.us/my.php?image=sig8hw.jpg' border='0' alt='user posted image' />
skawful is offline   Reply With Quote
Old 05-22-2004, 09:28 AM   #5 (permalink)
Robdrmer1016's Avatar
Robdrmer1016 is an unknown quantity at this point
you may want to try and find some resistance in the circuit such as the metal on the taillights may need some cleaning with steel wool or something like that. I believe the brake light circuit warning is flashed because there is something in the circuit that is causing the bulbs not to get full power but they still will work. Just an annoyance for us. Then check the bulbs maybe change them, check the things that hold the bulbs in place and then if that doesn't work change the brake light switch.
<img src='http://www.bmw-forums.com/forum/uploads/photo-3078.jpg' border='0' alt='user posted image' />
'93 325i 5 Speed
-Clutch Stop
-Window Tint
-2 12&quot; MTX subs
-Debaffled Airbox
-16&quot; Double Spoke Rims
-OEM Clear Corners and Tails
Robdrmer1016 is offline   Reply With Quote
Old 05-22-2004, 09:49 PM   #6 (permalink)
Mrcapitan is an unknown quantity at this point
Guys I had the same problem with the brake lights, so I went and changed both bulbs and got rid of it.
Mrcapitan is offline   Reply With Quote
Old 05-22-2004, 10:18 PM   #7 (permalink)
Boxxman is an unknown quantity at this point
I have the same problem, and after inspecting it myself I found that the plastic in the taillight interior was worn away. This causes the plastic bulb holder to become loose and thus causes a bad or inconsistant connection. I would recommend fixing this however you can if your plastic is a little worn, the replacement part is the entire taillight section and runs $198 plus tax.
Boxxman is offline   Reply With Quote
Old 05-22-2004, 10:58 PM   #8 (permalink)
CiscoKid's Avatar
it only happens to me when it is moist out
Brake Light Circuit Warning (again) Stamey 3-Series (E21, E30) 11 03-05-2005 07:05 PM
Annoying Brake Light Circut Failure NyteRyda 3-Series (E36) 14 01-21-2005 09:14 AM
Brake Light Circut Check Light sre2114 3-Series (E36) 1 10-16-2004 10:36 AM
brake light circut bluee36e36 3-Series (E36) 3 07-13-2004 04:43 PM
