brake light circuit fail - BMW Forum - BimmerWerkz.com
Old 08-09-2004, 07:55 PM   #1 (permalink)
AutoFan is an unknown quantity at this point
Okay just got my car back from the shop today and all of a sudden the check light comes on and says i have a brake circuit failure? i checked all the bulbs and the fuse.
so what is it?
AutoFan is offline   Reply With Quote
Old 08-09-2004, 07:59 PM   #2 (permalink)
Reedalicious's Avatar
Reedalicious is an unknown quantity at this point
Send a message via MSN to Reedalicious
Its a switch under the steering wheel is what i have read. I dont think its a big deal to fix, like $20. Search the forum, becuase alot of other people have this problem.
Reedalicious is offline   Reply With Quote
Old 08-09-2004, 08:01 PM   #3 (permalink)
69th Gear Member
BeachBunny's Avatar
Car: 1996 328IS
BeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond repute
That happened to me a while ago. I checked, and the lights worked normally. Everything LOOKED fine... but the fuse just needed replacing... I don't remember if it was getting a bit wobbly in it's old age? Anyways, what I DO remember is that it took about $10 or so to have the mechanic fix it.
BeachBunny is offline   Reply With Quote
Old 08-10-2004, 07:46 AM   #4 (permalink)
wavewuver is an unknown quantity at this point
Been there, done that. Most likely it's your brake switch.
Try this link: http://www.geocities.com/karlkarlb/brakeswitch.html
wavewuver is offline   Reply With Quote
Old 08-10-2004, 08:03 AM   #5 (permalink)
john_18 is an unknown quantity at this point
My car has the same problem but it doesnt show up until it rains really hard or is really damp outside. Im not too bothered about it. I htink i saw replacements for $8
Alpine White 328 IS, Pioneer Head Unit, Jensen Band pass box, debaffled air box w/ K&N filter, supersprint exhaust. clear corners and side markers, More to come....
john_18 is offline   Reply With Quote
Old 08-10-2004, 02:45 PM   #6 (permalink)
bimmerboy328i's Avatar
bimmerboy328i is an unknown quantity at this point
Send a message via AIM to bimmerboy328i
The replacement can be 11.00 or 30.00. If you have cruise control, then you need the 4-prong one which is 30.00. The 2-prong one is the 11.00 one. Just replaced mine, haven't seen the message since.
Part #: 61318360417
Diagram
- 97 M52 Beast - Vortech V-1 Supercharger Setup - Dinan Software - 28.8lb Injectors - 9psi - ZKW's - OEM Clears - DoubleSpoke II's - OEM M3 Spoiler - OEM M3 Front Bumper - 20% Tint - CCFL Angel Eyes - 6K Xtec HIDs in ZKWs - 6k H1 based D2S HID's in Foglights - Bilstein Sport Shocks - Eibach Sportline Springs - Cosmos Racing CAI - M50 Manifold Swap - UUC Motorwerks SystemU Exhaust - Fan Delete - 3.15 LSD -
bimmerboy328i is offline   Reply With Quote
Old 08-10-2004, 03:12 PM   #7 (permalink)
Car: 2008 128i
easy to replace. takes about 10-20 min...
remove lower dash.
break old switch out.
push new one in.
put lowerdash back on
no more message as long as that was the problem and you hooked everything up.
2008 128i Jetblack
Old 08-10-2004, 04:57 PM   #8 (permalink)
RIBEMR26's Avatar
Just did mine also, follow the diy EXACTLY...be patient and disconnect the wire harness from the switch before you tear it out, if you don't you could break some of the wires and turn a half hour job into a 2 and a half hour job....don't ask
Clear Corners and Sidemarkers
Brake Light Circuit Warning (again) Stamey 3-Series (E21, E30) 11 03-05-2005 07:05 PM
Brake Light Circuit? jbnery6465 3-Series (E36) 11 02-17-2005 04:18 PM
Brake Light Circuit Then Amp Wont Turn On epistemology Audio and Electronics 2 09-27-2004 06:19 PM
Brake light circuit Steinkek 3-Series (E36) 5 08-28-2004 09:55 PM
OBC - brake light circuit bimmerbill 3-Series (E36) 6 12-02-2003 11:43 AM
