Brake Light Circuit - BMW Forum - BimmerWerkz.com
Old 11-26-2004, 10:30 PM   #1 (permalink)
precision0904's Avatar
precision0904 is an unknown quantity at this point
Send a message via AIM to precision0904 Send a message via Yahoo to precision0904
it says brake light circuit(check manual book) but i dont have one so i was wondering if someone could tell me. my brake light work and it comes and goes. it never stays for long.
precision0904 is offline   Reply With Quote
Old 11-27-2004, 12:23 AM   #2 (permalink)
llzoom_zoomll is an unknown quantity at this point
Send a message via AIM to llzoom_zoomll
[snapback]238183[/snapback]
i dont get what you mean by this. it comes and goes? what never stays for long?
You think gas is expensive? CHECK THIS OUT:
Lipton Ice Tea 16 oz $1.19 ...........$9.52 per gallon
Ocean Spray 16 oz $1.25 .......... $10.00 per gallon
Gatorade 20 oz $1.59 ..... $10.17 per gallon
Diet Snapple 16 oz $1.29 .......... $10.32 per gallon
Evian water9 oz $1.49..........$21.19 per gallon?
Brake Fluid 12 oz $3.15 ........... $33.60 per gallon
Pepto Bismol 4 oz $3.85 ........ $123.20 per gallon
Vick's Nyquil 6 oz $8.35 .... $178.13 per gallon
llzoom_zoomll is offline   Reply With Quote
Old 11-27-2004, 12:32 AM   #3 (permalink)
Power Shifting
Cruzin 323is's Avatar
1 of 2 things... one, u can change the brake light circuit in the trunk.. which can be done at a mechanic/dealership... price??? (dunno)
two, go in the fuse box and check to see if any fuses are blown.. thats what i did, and hasn't been back since...
do a search.. this is a very popular item talked about all the time!
-SOLD..
R.I.P Fast 6
Old 11-27-2004, 12:35 AM   #4 (permalink)
Moderator
Dirty_Tool's Avatar
most common cause is the brake switch
DT
Old 11-27-2004, 03:08 AM   #5 (permalink)
Threadkiller
bitcore's Avatar
1. Fuses. Duh. Go ahead and replace any of them that appear to be blown.
2. Replace the bulbs. Go ahead and replace both of them with a fresh bulb. The brightness will match with each other, etc. and you dont have to worry about them burning out anytime soon again. This could very well fix it. One time, one bulb filiment broke, (blew) but it landed on the other lead, so the bulb was still working, but when I hit bumps or something, the filiment would shake off and sometimes it'd shake back on. That was puzzeling to me for about a week You don't need OEM BMW lights, NAPA's got them, I'm sure other places have them too. It's cheeper that way. A light bulb is a light bulb.
3. Replace the brake light switch. It's under the dash, hooked to a bracket infront of the brake pedal arm. DO NOT buy the switch from bavarian autosport, it's VERY LOUD and makes an AWFUL clicking noise... I even tried disassembling it to fix the noise and wound up breaking it even more. Go to the dealership and get the brake switch.
There are 2 kinds of brake switches, 2 pin, and 4 pin. If you have cruise control, you have the 4 pin. You can see if you take the leg panel (under the steering wheel) off with the 3 screws. 2 screws facing the front of the car on either sides of the steering wheel, and 1 screw facing up on the underside, close to the transmission. Unhook the vanity light and the "Bing" speaker and put the thing aside. Go ahead and take it off to identify if you have the 4 pin (it's got 4 wires going to it) or the 2 pin (it's got 2 wires going to it). Go to a dealership or call them and order the E36 (2 or 4)-pin brake light swithch.... Bimmerparts... Wherever, just get an OEM switch and not an aftermarket one, then you wont have a loud ass clicky one that you throw away cause it sucks and was a waste of 30$
If it's neither of those 3, then you have a wiring fault. That's bad. It could be anywhere.
Brake Light Circuit Warning (again) Stamey 3-Series (E21, E30) 11 03-05-2005 07:05 PM
Brake Light Circuit Then Amp Wont Turn On epistemology Audio and Electronics 2 09-27-2004 06:19 PM
Brake Light Circuit Warning? Laker 3-Series (E36) 10 08-31-2004 11:00 PM
Brake light circuit Steinkek 3-Series (E36) 5 08-28-2004 09:55 PM
OBC - brake light circuit bimmerbill 3-Series (E36) 6 12-02-2003 11:43 AM
