Brake light came on! - BMW Forum - BimmerWerkz.com
Old 04-19-2006, 01:16 PM   #1 (permalink)
Wonderboy's Avatar
Car: 98 M3 Sedan
Wonderboy is on a distinguished road
My brake light came on and i've heard you have to change pads and rotors. Not just the pads. Is this True? And if so what make the 1998 e36 M3's so unique that that has to be done.
I had a 78 300cd benz, and though i realize the m3 is in a whole different class, i never changed the rotors on that benz because the rotors still had plenty of life in them.
Just trying to get to the bottum of this.
Wonderboy is offline   Reply With Quote
Old 04-19-2006, 01:55 PM   #2 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
You don't absolutely have to change the rotors, but it's not a bad idea. BMW rotors are softer than most, and the new pads will immediately adopt the worn characteristics of the old rotor, i.e. grooves etc.
Lindsay fan club member.
Old 04-19-2006, 03:40 PM   #3 (permalink)
Wonderboy's Avatar
Car: 98 M3 Sedan
Thanks that is good to know. Is it a weekend job or can it be done after work?
Old 04-19-2006, 03:53 PM   #4 (permalink)
walshja is an unknown quantity at this point
changing the brakes takes about 1.5 hours, and I would change the rotors, you can get replacements for about $40 each, althought that price was for non-M3 rotors.
i just changed my brakes and it is the easiest DIY job you can do to save hundreds of $$$
1994 325iC, 130k miles
walshja is offline   Reply With Quote
Old 04-19-2006, 05:06 PM   #5 (permalink)
tomctx's Avatar
Just take a look at the rotors and see what shape they are in. Deeply grooved? Probably need replacing.
Old 04-19-2006, 05:49 PM   #6 (permalink)
Wonderboy's Avatar
Car: 98 M3 Sedan
I can feel a lip on them but honestly it doesn't feel bad at all!
Old 04-19-2006, 09:23 PM   #7 (permalink)
tomctx's Avatar
Then I wouldn't worry about it. Unless they are deeply grooved , probably allright.
Old 04-20-2006, 03:33 AM   #8 (permalink)
Wonderboy's Avatar
Car: 98 M3 Sedan
Thanks much...
Brake Light Circuit Warning (again) Stamey 3-Series (E21, E30) 11 03-05-2005 07:05 PM
HELP, e36 brake light curcuit fault code theogill 3-Series (E36) 4 08-27-2004 07:48 AM
After tail-light upgrade, left brake light is gone mostwired 3-Series (E36) 3 11-26-2003 05:13 PM
