Brake Light - BMW Forum - BimmerWerkz.com
Old 07-09-2004, 04:46 AM   #1 (permalink)
Rich328's Avatar
Rich328 is an unknown quantity at this point
Send a message via MSN to Rich328
My Brake disc/pad warning light has come on, on my dash-display...
I am wondering whether I need to change the pads this weekend, or will it be alright if I leave it a couple of weeks?
Also, do I need to change the discs at the same time as the pads..... my car is a 328i
Should I just change them for normal/stock discs/pads, or should i upgrade them?
Rich328 is offline   Reply With Quote
Old 07-09-2004, 06:44 AM   #2 (permalink)
How many miles on the car? You will need a new sensor or sensors (left front/right rear) but if you have no indication of disc warpage (vibration through brake pedal when braking) I would leve the discs alone (unless you want to replace them and they are approaching 100,000 miles). If you do replace them, replace the hold down screws as well.
Old 07-09-2004, 07:00 AM   #3 (permalink)
Rich328's Avatar
the car has 62200 miles on the clock, and i've probably done about 40miles since the light came on.
Do I need to change the pads now - before I do too many more miles?.... or will it be ok for a couple of weeks (approx. 400 miles - got an airport trip to do aswell - down the highway/motorway).
Also sometimes during heavy braking it feels like the pedal is pumping back at me.
Old 07-09-2004, 07:55 AM   #4 (permalink)
Fadec40 is an unknown quantity at this point
You have time before the change. I have a 328i also. Usually . once that light illuminates, it is recommended that the sensor be changed as well.
Fadec40 is offline   Reply With Quote
Brake Light Circuit Warning (again) Stamey 3-Series (E21, E30) 11 03-05-2005 07:05 PM
HELP, e36 brake light curcuit fault code theogill 3-Series (E36) 4 08-27-2004 07:48 AM
After tail-light upgrade, left brake light is gone mostwired 3-Series (E36) 3 11-26-2003 05:13 PM
