Brake judder - BMW Forum - BimmerWerkz.com
Old 09-20-2004, 07:05 AM   #1 (permalink)
Rich328's Avatar
Rich328 is an unknown quantity at this point
Send a message via MSN to Rich328
I've finally come to the asumption that the front brake discs on my car need replacing. Because of the juddering coming through the steering wheel.
I've just had the pads changed at the Main dealer.... so do i need to change them again? or can i just do the discs?
Also does anyone recommend any performance upgraded discs for the 328i?
cheers
Rich328 is offline   Reply With Quote
Old 09-20-2004, 07:37 AM   #2 (permalink)
Sk1d's Avatar
Sk1d is an unknown quantity at this point
If you've just recently had your pads changed, when u take them off check them for any signs of damage or uneven wear that coulda been caused by the old discs. If they look ok then u should have no problems putting them back in with a new set of discs. Avoid refitting pads that are cracked or excessivley worn...
Good luck...
Me-Chanic
Sk1d is offline   Reply With Quote
Old 09-20-2004, 10:25 AM   #3 (permalink)
BMWBeauty416's Avatar
Car: '00 M-B CLK430 Cabriolet
BMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to all
Send a message via AIM to BMWBeauty416 Send a message via MSN to BMWBeauty416 Send a message via Yahoo to BMWBeauty416
did you have the disks turned/reworked?
~*Teg*~
BMWBeauty416 is offline   Reply With Quote
Old 09-20-2004, 10:48 AM   #4 (permalink)
/Banned
okczy21 is an unknown quantity at this point
you need rotors it fixed my problem of the steering wheel wobbling, they are just warped a little due to heat, your probally like me and slow down at the last second, huh?
okczy21 is offline   Reply With Quote
Old 09-20-2004, 11:27 AM   #5 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
~*Teg*~
If a rotor is out of BMW specs... meaning.. they are worn... you can NOT turn your rotors.. its is very specific to not rework BMW rotors... they are made to last untill the spec says they are done.. if you turn them.. or rework them past this.. they have a very high chance of cracking.. or coming apart if used...
Les
1997 E36 M3 1990 E30 325i
Old 09-20-2004, 12:04 PM   #6 (permalink)
ex owner/admin
Furious's Avatar
most places, especially the dealer should know to machine the rotors, i do it every time, just to get rid of all the imperfections that rotor might have. if the rotor had enough beef than im sure you may be ok. however id just give then a good check for warpage
Old 09-20-2004, 12:10 PM   #7 (permalink)
Originally posted by 97alpineM3+Sep 20 2004, 12:07 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (97alpineM3 @ Sep 20 2004, 12:07 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin-BMWbeauty416@Sep 20 2004, 12:05 PM
~*Teg*~
Les[/b][/quote]
learn something new everyday
~*Teg*~
Parking brake not releasing GnarlyCow 3-Series (E46, E90) 13 07-29-2004 03:39 AM
service questions thamindzzeye 3-Series (E36) 4 04-30-2003 02:40 PM
