| thanks for that, went relatively hassle free today! All discs and pads replaced and brake fluid changed!
However while doing all this I now need a bit of further advice!
While doing the rears I noticed the inner edge of both tyres were heavily worn (and will need replacing in the next month or two!). The problem is the car has 17" BBS alloys on (with 235/40/17s on the back and koni coilover fully adjustable suspension. Even when set on highest setting the tyre sits right into the arches and unless set relatively hard will rub. I would like to find a way to higher the car maybe 1cm so I can set the suspension a slight bit softer and also would a camber kit resolve the uneven tyre wear issue and is this suitable for my car as the tyre sits right into the arch already!
Thanks for any further help! |
