brake disscussion - BMW Forum - BimmerWerkz.com
Old 09-20-2005, 12:24 AM   #1 (permalink)
theironm0nk is an unknown quantity at this point
brake disscussion
All right I had a disscussion over what brake upgrade would be best. Should I go from the no name rotors currently to oem BMW rotors, cross drilled, slotted, or both. Due to my living conditions I can't afford to spend 3-4k on just brakes. I did agree I do drive spirited and I have had out gas issues, but I don't do it enough to put track type stress which won't be enough to damage cross drilled.
I was thinking about going with bavarian autosport ultimates from bavauto or uuc slotted . But I have also thought about obtaining BMW OEM M3 floating rotors but would they fit?
Yes I will be upgrading to uuc SS brake lines.
theironm0nk is offline   Reply With Quote
Old 09-20-2005, 08:33 AM   #2 (permalink)
For Teh Walrus?
WALSRU's Avatar
Car: 1980 635csi euro
WALSRU is a splendid one to beholdWALSRU is a splendid one to beholdWALSRU is a splendid one to beholdWALSRU is a splendid one to beholdWALSRU is a splendid one to beholdWALSRU is a splendid one to beholdWALSRU is a splendid one to beholdWALSRU is a splendid one to behold
Send a message via AIM to WALSRU Send a message via MSN to WALSRU
My vote is for the uuc slotted from those options. I'm not a big fan of drilled and slotted like those ultimates.
"I would not know what the spirit of a philosopher might wish more to be than a good dancer."
- Friedrich Nietzsche
1980 635csi Euro . . . Current
1985 535i . . . Soon to be parted out
2001 Subaru Forester . . . DD
WALSRU is offline   Reply With Quote
Old 09-20-2005, 10:58 AM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Ok... a brief explanation for you....
Slotted rotors... Drilling a rotor is often believed to disrupt the integrity of the rotor. Thus slotted rotors are known to be stronger due to the fact that drilled rotors have stress points unlike those of most slotted rotors. Another argument or fact that could be brought is surface area. With a drilled rotor you have less area touching the brake pad.
Drilled Rotors... The cooling effect of a drilled rotor is beyond compare of that of a slotted rotor. Though a slotted rotor performs better than a stock rotor. The slotted rotor doesnt have enough places to put the gases that build from heat produced by friction. Another upside to drilled is wet driving. These rotors have a high tendency of throughing dirt and sand and mostly water by centrifugal force through the holes and preventing the same build between the rotor and pad that causes brake fad and loss.
Now which to get... my personal opinion... probably drilled. I've had better response with them... meaning you dont have to push the brake pedal all the way down before the pad bites the rotor... as for wet driving... My car is a daily driver sometimes... and it often meets rain... and I like being able to brake quickly in the rain. As for strength... I've never had one warp on me... and I've never had one fail on me...
I also use Zimmerman Cross Drilled Rotors.... you can get those easily at TMS. They are not exspensive... as I plan to upgrade to a larger brake system in the future.
Good Luck and I hope I helped some.
Les
1997 E36 M3 1990 E30 325i
Old 09-20-2005, 02:41 PM   #4 (permalink)
Well TMS seems like a good buy and now you just made my decision harder. Should I go with the ultimates or zimmerman cross drilled
I do know I'm switchin over to ss brake lines and axis ultimate pads.
I'm going with UUC brake lines because of the blue protective covering which prevents fraying (which hurts)
Old 09-21-2005, 10:54 PM   #5 (permalink)
Thanks alpine; I have decided to buy the TMS brake package with cross drilled rotors. But I have decided to get the ss brake lines from UUC as they seem to have better quality lines.
Old 09-23-2005, 09:00 PM   #6 (permalink)
theruss1an1's Avatar
Car: Needs momentum
theruss1an1 is an unknown quantity at this point
Send a message via AIM to theruss1an1
You can also get E46 brakes. 32X all you need is the 300 mm rotor and caliper braket. 330 you need the calipers, rotors, etc. Im going to switch to the larger diameter of the E46 32X rotor.
What are the pads that most of you guys have?
-Serge
theruss1an1 is offline   Reply With Quote
Old 09-24-2005, 12:23 AM   #7 (permalink)
I'm getting the axis ultimates.
Old 09-25-2005, 10:53 AM   #8 (permalink)
mech9T8's Avatar
mech9T8 is an unknown quantity at this point
I recently upgraded to OEM replacement Brembo rotors and Hawk HPS pads. Definitely better than OEM and alot less dust.
I am very happy with the results.
<img src='http://www.geocities.com/royb9t8/MY_BMW_2.jpg' border='0' alt='user posted image' />
<span style='color:blue'>My ass may be dumb, but I ain't no dumb ass!</span>
mech9T8 is offline   Reply With Quote
Parking brake not releasing GnarlyCow 3-Series (E46, E90) 13 07-29-2004 03:39 AM
