Brake circuit Code?? - BMW Forum - BimmerWerkz.com
Old 02-14-2006, 07:32 PM   #1 (permalink)
Lethal325is's Avatar
Lethal325is is on a distinguished road
Hello everyone im new to the forum, not new to the cars luckily! I just recent bought a 1993 325is few days after buying the car the OBC flashed a brake light circuit check owners manual code?? Everything checks out fine in the brake lights? It only happens once twice a week. Has anyone heard of this?
Thanks in advance for the help. I also have a set of 18x8.5 wheels that came off of my 633csi will fit 6 7 8 ser cars best offer accepted.
Current Car- 93 325is Exhaust, Intake, side marker delete, Cross drilled/slotted rotors, other misc crap.
Old cars 94 750il, 84 633csi, 88 POS Ford Mustang GT
Lethal325is is offline   Reply With Quote
Old 02-14-2006, 09:53 PM   #2 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
99% chance you need a new brake light switch. Its a common problem we see at the BMW shop I work at.
My M50 Powered E30 Page
Old 02-14-2006, 11:09 PM   #3 (permalink)
ex owner/admin
Furious's Avatar
before you replace the switch, check your contacts on both sides of the brake light connectors,
Old 02-15-2006, 02:11 AM   #4 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
He said the lights work fine which leads me to think that the switch is starting to fail.
Old 02-15-2006, 10:32 AM   #5 (permalink)
tomctx's Avatar
My car did the same thing. I got the "brake light failure", "brake circuit failure" once or twice a day. I ordered the switch. Before it got to my house, some aftermarket lights I had ordered arrived. I installed the aftermarket lights and guess what? It's been over a month and there has been no " brake light" or "brake circuit " error on the OBC. Everything has been quiet. Might have been something wrong with my lights, don't know. And yes, my OEM lights worked every time I checked them, as do the new lights. I'm holding on to the switch, just in case.
Old 02-15-2006, 07:13 PM   #6 (permalink)
Thanks for the help, i am getting the red/clear tails, if problem still occurs, then looks like new switch goes in.
Old 02-15-2006, 09:46 PM   #7 (permalink)
WarNox's Avatar
where is this switch located?
<img src='http://www.geocities.com/thereisnothinglikeabmw/mycar1.jpg' border='0' alt='user posted image' />
WarNox is offline   Reply With Quote
Old 02-16-2006, 12:10 AM   #8 (permalink)
tomctx's Avatar
It is under the dash in front of the brake pedal.
Old 02-16-2006, 05:07 AM   #9 (permalink)
WarNox's Avatar
and what does it do?
Old 02-16-2006, 07:42 AM   #10 (permalink)
tomctx's Avatar
It turns on your brake lights when you push on the brake pedal to stop. And if you have the OBC, it triggers the failure codes when a bulb or some other part is broken.
Old 02-21-2006, 08:08 PM   #11 (permalink)
motown3's Avatar
motown3 is an unknown quantity at this point
It is the Brake Switch. Cheap, a little difficult to remove, simple to install. I tore mine apart getting it out, just be sure not to bend the mounting bracket.
&quot;Friends may come and go, but enemies accumulate&quot;
motown3 is offline   Reply With Quote
Old 02-22-2006, 07:31 AM   #12 (permalink)
jcy0001 is an unknown quantity at this point
heres the diy i followed when changing mine and havnt seen the error since
http://www.geocities.com/karlkarlb/brakeswitch.html
jcy0001 is offline   Reply With Quote
Old 02-22-2006, 06:46 PM   #13 (permalink)
WarNox's Avatar
but if the switch is broken and it turns on the break lights wouldnt that mean the break lights are also not working!?
Old 02-22-2006, 08:42 PM   #14 (permalink)
tomctx's Avatar
No. What it does is give you a false error code. You should, of course, check anytime you get the "brake light failure" or "brake circuit failure" codes. If the lights are working, then the switch is most likely faulty and giving false codes. There are four wires on the switch. Two are used to trigger the brake lights. And two are used to monitor the brake light system.
Old 02-22-2006, 08:46 PM   #15 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
I bet it's the brake light switch, like everyone said.
btw, got any pics of the wheels you're selling? And what are you expecting to get for them, aproximatelly, so i know what to offer.
Brake Light Circuit Warning (again) Stamey 3-Series (E21, E30) 11 03-05-2005 07:05 PM
Brake Light Circuit Then Amp Wont Turn On epistemology Audio and Electronics 2 09-27-2004 06:19 PM
HELP, e36 brake light curcuit fault code theogill 3-Series (E36) 4 08-27-2004 07:48 AM
OBC - brake light circuit bimmerbill 3-Series (E36) 6 12-02-2003 11:43 AM
