Bottom of engine knocking NEED HELP!!! - BMW Forum - BimmerWerkz.com
Old 02-24-2006, 10:21 PM   #1 (permalink)
Bleier325 is on a distinguished road
When the car is idling i am hearing knocking noise from the bottom of the engine and i can't figure out what it is.: I dont want to drive the car until i figure out what it is so if you could let me know what you think that would be great because i stuck not knowing what to do. Also I dont know if its relevant, but i have coolant leak that is comming from passengers side of the car up front by the rad. and coolant tank, im trying to track that down now also.
Bleier325 is offline   Reply With Quote
Old 02-24-2006, 11:10 PM   #2 (permalink)
7th Gear (SMG)
The leak is probably from the expansion tank/thermostat housing. That area (where it connects to the radiator by hose) is a typical area leak. If it isn't leaking where the thermostat goes in, you might be able to tighten the hoseclamp (follow the expansion tank down, if the last person who touched your radiator was nice, the hoseclamp screw will be visible. Get a long flathead).
What's the knocking noise sound like (I know, redundant question)? Is it more of a metallic rattle? From the bottom of the front then, not under the car like exhaust?
I suspect it could be several things - most are bad. It might be tied to your radiator leak, and you might have a failed water pump... or the bearings are shot...
1998 BMW e36 M3 Sedan
2003 MINI Cooper
Old 02-25-2006, 08:45 AM   #3 (permalink)
quality
Delmarco's Avatar
Engine knock is usually and most commonly caused by using lower than rated octane for your car. Remember for BMW e36/3 series use only 89 octane or higher. Do not use 87 octane?
Old 02-26-2006, 08:50 AM   #4 (permalink)
I cant figure out this knocking PLEASE HELP!
I only use 91 octane or above, thats all i have used since i got the car. Is there any mechanical problems that can be associated with knocking on the bottom end of the car i think closer to the drivers side and it is only noticable when the car is idling. Any input is great! Thanks
Old 02-26-2006, 10:20 AM   #5 (permalink)
dirtybeemer's Avatar
dirtybeemer is on a distinguished road
It is hard to diagnose like this it really could be anything whats the oil level like in your car the reason i ask is that it could a big end shell bearing or it might be the water pump ratteling it really could be anything the best thing to do is take it to a garage
dirtybeemer is offline   Reply With Quote
Old 02-26-2006, 10:55 AM   #6 (permalink)
walshja is an unknown quantity at this point
could be your VANOS, mine make a lot of noise . . .
1994 325iC, 130k miles
walshja is offline   Reply With Quote
Old 02-26-2006, 12:15 PM   #7 (permalink)
7th Gear (SMG)
But that's more of a rattle as well... Maybe it is something with the oil... whatever it is, knocking is worse than rattling, probably.
2003 MINI Cooper
Oil Leak From Bottom Of Engine??? BIG 730 1,6,7,8 - Series and Mini Cooper 3 12-19-2005 02:57 PM
E34 525i Engine Knocking riverarb 5-Series (E12,E28, E34, E39, E60) 6 10-21-2004 08:24 AM
