My e36 had the original siemens oxygen sensor on it and needs replacing.
My local store only stocks bosch ones and my emissions test (MOT) is tomorrow.
I've tried to fit the bosch, but it seems the only difference is the fitment to the socket (not the sensor, the other end of it where it connects to the electrical plug).
I was wondering if i could somehow cut the sensor off the new bosch and fit it to the old siemens electrical socket.
both sensors have 4 wires. The new bosch one has 2 white, 1 black and 1 grey. The old siemens one has 1 white, 1 black, 1 red and 1 yellow. On both the siemens and bosch, the connector pins are labelled 1,2,3 and 4, although its not clear as to which colour wires these correspond to.
Does anyone know if this is possible??
Please see pics. The first 2 are from the original Siemens sensor and the second 2 are the new Bosch one.
It appears that the electrical sockets are the same, and if so it would make sense that the wires were going to the correct pins even though they are different colors. However, if you are saying the plug won't fit , there is no reason why you couldn't cut the plug off and splice in the old one. The problem is there is no sure way to determine what wire goes to what pin. I'd follow the numbering convention and hope it was right. When I was sure that everything worked, I'd sloder the wires and cover the connections with heat shrink tubing.
I would check to ensure the electrical properties are the same. If one system is set to work with different sensor values, you will have trouble even if you do cut/splice the wires correctly.
That sucks your local parts store doesn't have it. You could buy one online and drive illegally 'till it arrives...
Ok. You clearly have an OBDII car. The OBDII car uses a Siemens ECU. The parts for that ECU won't work with the parts for the Bosch ECU. Don't do that.
Addicted to Speed Since 1997 Founding member of the GreenDragon Poo Flingers Club
Well i had a similar issue today. And after much time on the net i have found the following:-
Siemens sensor Function Generic sensor
Yellow sensor signal (5v) Black
Black senor ground Grey
Red Heater +ve (12v) White
White Heater -ve White
Hooked it all up, cleared the error codes. wend for a drive and checked the error codes again. Looks like its working.
Will know for sure after 500km, as my fault was high fuel consumption.
Also when i checked the error codes i had errors for both O2 sensors and for o2 sensor voltage. and DME.
Now im down to just the MAF error.
But putting a Bosch 3.5" MAF on a 328i with a seimens computer is a whole other thread.
Hi,
I've bought a set of sensors on the internet for my E36 323ti, and they arrived in the mail today.
The original sensors has yellow, black, red and white wires, and the new has black, gray and 2 white wires.
Before I connect the new sensors with the color combination you describe, I'd like to know if it's still working or if you have discovered some issues since your post?
I've read somewhere that if a sensor has a yellow and red wire it's a "Titan sensor", and then it can't be replaced with a generic sensor, but if it works for you I guess it'll work for me as well.
Since my last post i have replaced my MAF and had a tune. The excess fuel consumption had choked the o2 sensors. I replaced with a non-genuine sensor supplied with the correct plug already fitted. The ones i wired up may have worked again if i cleaned them but i was worried they may have gotten too hot which can damage them.
So while i think i had the wireing right, i dont currently have them fitted.
I have a percisten DME error however and when it comes up a short while later the maf and o2 sensor error comes up.
I think i may have to replace the DME, but i have a custom dynotune, so not sure if i can replace the DME without getting it dyno tuned again.
Im currently making 180whp from my 328i. using a 3.5" K&N filter and a heatsheild, bimmerworld ducting, M50 inlet manifold, 24lb bosch injectors and M3 exstractors. Exhaust is custon 2.5" single pipe,fuel consumption is aroung 9.5l/100km. So it is driving nicely, but i have errors to clear at service time. Does not seem to be affeting the drivability at all.
