BMW REV PROBLEM when idle - BMW Forum - BimmerWerkz.com
Old 11-23-2012, 09:23 PM   #1 (permalink)
bmw messed up is on a distinguished road
hello peoples. hope you all okay and I want to appreciate that you helping out peoples like me.
I have a BMW 2002 316ti se compact. petrol and converted on lpg.
problem just started recently. when I start my car, it rev on 1000rpm for a min then drop down 600-700 rpm. but while driving and car temperature goes on normal. then if i idle my car, the rev's start playing about.
the goes on 1000rpm and goes to 1600 rpm, then drop down to 1000rpm, the goes to 1600rpm. this procedure goes on and on, every after 15-10 seconds.
engine management light came on as well, but i don't know if it is because of rev problem or because of LPG converted. but rev problem happens while driving on petrol or lpg.
car drive good, i recently drove on 100mph, it worked fine. but only happens when its idle.
pleaseeeeeee can one tell me what problem is it ?
bmw messed up is offline   Reply With Quote
Old 11-24-2012, 07:09 PM   #2 (permalink)
Ivan413's Avatar
Car: 95 BMW 318i
Ivan413 is on a distinguished road
Could be the sign of a bad o2 sensor(s)
Sent from my iPhone using AutoGuide.com Free App
Just your avg 17 year old with an e36 318i as a DD!
Ivan413 is offline   Reply With Quote
Old 11-24-2012, 07:47 PM   #3 (permalink)
Ivan413's Avatar
Car: 95 BMW 318i
Or your maf sensor
Old 11-25-2012, 05:59 AM   #4 (permalink)
bmw messed up ( idle problem)
Originally Posted by Ivan413 View Post
Or your maf sensor
if MAF sensor is bad then car should go in limp mode, if am right?
Old 11-25-2012, 07:25 AM   #5 (permalink)
Ivan413's Avatar
Car: 95 BMW 318i
Yeah most likely enter limp mode have u experienced loss of power?
Old 11-25-2012, 07:34 AM   #6 (permalink)
Ivan413's Avatar
Car: 95 BMW 318i
If you haven't experienced power loss I'm guessing u might have a vacuum leak somewhere.
Old 11-25-2012, 07:44 AM   #7 (permalink)
Ivan413's Avatar
Car: 95 BMW 318i
Sorry my phone bugged up and posted it twice
Old 11-25-2012, 09:13 AM   #8 (permalink)
nope it didn't go in limp mode at all. i recently hit 100mph, it runs smooth.
just now, i was looking into it. there is air intake box, it got a small hole because of pulley rubbing.
i found this link, it is exactly the same. 2002 E46 316ti Air filter Lower Box Damaged?
do u think, it can cause revs goes up and down?
plus i got a maf cleaner, i just sprayed the sensor too.
Old 11-25-2012, 09:25 AM   #9 (permalink)
Ivan413's Avatar
Car: 95 BMW 318i
I don't think it's your maf at all. You might as well check ur intake box and ur vacuum box for holes .
Old 11-25-2012, 10:33 AM   #10 (permalink)
hey thaks for your mail back
vacuum box is the big box in which maf is fixed?
i took the both boxes out and looked for any other holes, but only found one, which i already mentioned and super glued it with plastic, it is fine now. i also cleaned the maf with maf cleaner. all pipes were intact.
i drove the car, firstly the rev's were really bad. it was n 600, i felt like engine gona stop.
after drove little bit, everything since to be fine. but after i put engine on idle. revs start going up again but not that quick as it used to before.
it is same on petrol and lpg.
what else do u think it could be?
Old 11-25-2012, 12:57 PM   #11 (permalink)
Ivan413's Avatar
Car: 95 BMW 318i
How many miles does ur bmw have ?
Old 11-25-2012, 01:39 PM   #12 (permalink)
milage is 64000
Old 11-25-2012, 02:01 PM   #13 (permalink)
Ivan413's Avatar
Car: 95 BMW 318i
Oh ok I was gonna say that it could be you idle control valve is dirty with all the built up carbon because your suppose to clean that about every 80k ...so it's your choice if you wanna take some q-tips and rubbing alcohol and clean that up if it looks dirty and hopefully that solves the idle problem in the mean time I'm gonna research your problem further and ill tell u what I come up with
Old 11-25-2012, 03:31 PM   #14 (permalink)
thankyou mate.
i got a small up date. the rev's working little better then before. if i say out of 100%, its 50% better now.
today i opened the box in which maf is fixed and the box underneath, where i fixed the hole.
u mentioned idle control valve, how shall i reach there?
is it close to where i went so far?
other question i need to ask, if i do the diagnostic check, will is show anything?
the check is 40quid here and labour is more in manchester. soo would be really thankful if u can point out how to fix. i will try to do it myself.
Old 11-25-2012, 04:32 PM   #15 (permalink)
Ivan413's Avatar
Car: 95 BMW 318i
Yeah the IDV is near where you have been working. Just a little bit further and I'm hoping this solves your problem I have some pictures of diagrams of how to get to it. BMW REV PROBLEM when idle-imageuploadedbyag-free1353882581.831317.jpgBMW REV PROBLEM when idle-imageuploadedbyag-free1353882594.990702.jpgBMW REV PROBLEM when idle-imageuploadedbyag-free1353882745.582755.jpgBMW REV PROBLEM when idle-imageuploadedbyag-free1353882757.248769.jpg
possible idle problem ncktuley1 3-Series (E36) 1 05-14-2012 05:08 AM
e36 318 idle problem please help bmwmad1 3-Series (E36) 1 01-17-2009 12:58 PM
Idle Problem Rich328 3-Series (E36) 7 09-04-2005 03:46 PM
Idle Problem Rich328 3-Series (E36) 4 08-23-2005 04:38 AM
idle problem gman 3-Series (E36) 1 02-21-2004 03:05 PM
