Originally Posted by tat2lu i was driving when i turn my head lights on then my radio shuts off and the cluster lights come on and stay on (check engine,abs,and srs)i got to park the car,now it wont start .i have full power but it wont start..
i have changed the dme relay but still nothing can anyone help. i dont know what to do..iam thinking maybe another relay..Please. HELP!! |
1st Welcome to Bimmerwerkz.........
Sounds like a low voltage problem.......with either the battery or alternator.
So attach a voltmeter to your battery with the car running......
you should have 13.5 to about 14.5 volts engine running & nothing turned on & a little over 12 volts with everything turned on.......
Things you can do, remove your battery & fully charge it, then bring it to a Pep Boys or Advanced Auto parts store & have it load tested, if it checks ok!
and you still have a low voltage issue then the alternator is bad.....
good luck.....
jb
