BMW Engine Wiring Harness. - BMW Forum - BimmerWerkz.com
Old 01-28-2004, 08:30 AM   #1 (permalink)
bigkranium is an unknown quantity at this point
Last summer, my 325i failed the NJ emissions on account high hydrocarbons (HC).
The check engine light did not pull any codes back then. As the entire NJ inspection thing has become a huge and possibly $$$$$ boondogle, I just ignored it. Car ran fine in fact-30 mpg and all that.
Two days ago, the check engine light began to blink. I pulled a 1221 (O2 sensor). What a surprise. This was the circuit that gave problems during the previous inspection two years ago.
Fact is-the O2 sensor was replaced as a result of that first inspection problem.
The CE light still came on. The root cause was (supposedly) found to be a damaged
wiring harness leading up to the O2 sensor. I had the dealer "repair" that item-because the cost of an engine wiring harness was supposed to be $$700.
Now, I want to repair the car and am looking for some feedback. Questions:
1) can the car fail emissions and not show a problem via CE light 2) Now that the car has a problem in the O2 sensor circuit-could the sensor have failed ?
3) should I just bite the bullet and replace the wiring harness ?
Thank you
bigkranium is offline   Reply With Quote
Old 01-28-2004, 12:16 PM   #2 (permalink)
TECH's Avatar
Yes, yes, and no/maybe/possibly. :P
Need lots of help - ECU, wiring harness advice trunks0584 3-Series (E36) 10 12-29-2008 09:37 PM
Engine wiring harness zinger 3-Series (E36) 0 09-20-2005 12:58 PM
Wiring Harness nookatee Audio and Electronics 4 08-08-2005 03:18 PM
Different Wiring Harness bmwfam123 3-Series (E36) 0 10-10-2004 05:56 PM
