Bmw Brake Squek Or something is squeking - BMW Forum - BimmerWerkz.com
Old 08-28-2004, 12:46 PM   #1 (permalink)
p3rsian is an unknown quantity at this point
hey
when i drive after a while and some braking.
like when im in a parking lot just gion straight at low speed , doesnt make diffrence if its in gear or not i hear like brake squeks but im not braking
when i pull the ebrake a little up i hear it louder. i use ebrake sometimes i mean i used it alot when i bought my car. now it feels like it doesnt work to well
is it possible to be my rear brakes ?
p3rsian is offline   Reply With Quote
Old 08-28-2004, 09:31 PM   #2 (permalink)
ChahalzBMR is an unknown quantity at this point
Sounds like your e-brake is little jammed. Does your car jerk to one side when you use the e-brake? Try parking up hill and use the e-brake, if it starts to roll then you know for sure your e-brake is not working. You can adjust it if nothing else is wrong with it, hopefully you have no hold down pins that are broken. Two months ago, my hold down pin was broken for the driver side and kept making noise when I use to drive. I thought it was the rims and after carefull inspection, it turned out to be the hold down pin. Not an expensive fix if you can do it your self. You can buy the entire kit from BMW for like $20. If you need to tighten the cable for your e-brake, here is a link to help guide you....
http://www.pelicanparts.com/bmw/techarticl..._Adjustment.htm
Hope this helps...
<img src='http://img43.exs.cx/img43/275/Resize.jpg' border='0' alt='user posted image' />
Body: 318i 4 door
Mods: M50 engine, Jim C chip, light-weight flywheel, dual cat-back custom exhaust, 3:15 lsd, euro headlights w/angel eyes, 5300K HID, smoked corner lights, FK Motorsports foglights (crystal clear), ABS plastic upper eyebrow, clear side markers, M3 powered side mirrors w/LED, blacked out grill, M3 lighted shift knob, 17&quot; ROH Furry wheels w/Kumho tires, Brembo cross drilled rotors and Hawk performance brake pads all around, PSS9 Bilstein and H&amp;R coil over kit, front strut bar and Alpine alarm.
ChahalzBMR is offline   Reply With Quote
Old 08-28-2004, 11:47 PM   #3 (permalink)
yep it jerks to the right rear side of the car when i use the ebrake but it holds on a hill .. what should i do ?
Old 08-29-2004, 12:15 AM   #4 (permalink)
zeidakiss's Avatar
zeidakiss is an unknown quantity at this point
i think you need to get some new ebrake shoes and you might need to get some anti squeel compound just to make sure.
zeidakiss is offline   Reply With Quote
Old 08-29-2004, 12:19 AM   #5 (permalink)
zeidakiss's Avatar
oh yeah just remembered i think you shoes are not coming off the rotor when you let down the ebrake. the same thing happened with my benz
Old 08-29-2004, 01:05 AM   #6 (permalink)
Threadkiller
bitcore's Avatar
mine do this sometimes and I have to like.... re-seat them or somthing.
Roll the car backwards, like, put the car in neutral, open the door, and push the car backwards with your foot. Get it moving at about 2-3 mph. Jam the e-brake to a stop. Don't roll the car too fast where you'd skidd, just fast enough to make the back end suspinsion raise up a few inches.
This stops the sqeeking noise for a while untill I use the ebrake again.
Better solution would be to actually fix the problem... not just use a solution to shut it up
Parking brake not releasing GnarlyCow 3-Series (E46, E90) 13 07-29-2004 03:39 AM
