BMW 318i 92Model E36 Starting Problems - BMW Forum - BimmerWerkz.com
Old 09-12-2005, 01:46 AM   #1 (permalink)
deanbelich is on a distinguished road
Hi i was just wondering what could be the problem when my car is kicking over, when starting it up.
Sometimes when i start the car up it will keep trying to kick over and over again. Then when i back off and try again without touching the accelerator it will do the same thing again try to start up then go back to "reds". The only way i can start the car up is by applying the accellerator fully to kick it over; like starting a carborator engine.
I have changed the spark plugs to the high quality ones irridium, changed fuel filter. I am not sure what this could be.
It only happens sometimes and happens all over the place, just after i have turned the car on or even if i leave the car off for 10hrs, but sometimes again if i have had the car off for a day it will start up normally. It only happns sometimes but i cant seem to find the problem. And when it does start up it has a rough idle and the lights dim and after about 30 sec its normall.
I thourght it might be the battery as sometimes when i start off to drive the battry light stays on and then when i speed up the battery light turns off.
Thanks
deanbelich is offline   Reply With Quote
Old 09-12-2005, 08:07 PM   #2 (permalink)
VLAD_325is is an unknown quantity at this point
maybe a dirty fuel injectors?
did you do all the maintenance including cleaning your idle control valve?
my car also coughing a little bit in the mornings and i haven't found the solution yet..
check your battery voltage, then possibly bring your car for a fuel system cleaning...
maybe that would help.
VLAD_325is is offline   Reply With Quote
Old 09-14-2005, 12:32 AM   #3 (permalink)
umm also i have noticed it is a auto, when it does kick over sometimes it idels low and the interior lights dimm and then after 30seconds it returns back to normal idal. It feels like for a second the car is going to stall.
Thanks.
Old 09-14-2005, 07:53 AM   #4 (permalink)
how do u clean your idle control value
Old 09-14-2005, 01:24 PM   #5 (permalink)
WarNox's Avatar
http://www.bmwe36tips.20m.com/unstable-idle.htm
<img src='http://www.geocities.com/thereisnothinglikeabmw/mycar1.jpg' border='0' alt='user posted image' />
WarNox is offline   Reply With Quote
Old 09-21-2005, 09:14 AM   #6 (permalink)
Nah it still happens the problem... i think it might be the fuel pump.. its the only thing we haven't changed.
Dean
Old 09-21-2005, 10:43 AM   #7 (permalink)
quality
Delmarco's Avatar
what about oxygen sensor and air mass flow sensors?
can you also hear the engine reving/vibrating wildly when you are in idle and you turn the AC on or power the windows all the way up?
Old 09-21-2005, 11:41 AM   #8 (permalink)
someguy's Avatar
someguy is an unknown quantity at this point
Clean your grounds, they may have extreme corrosion...just my 2 cents
<span style='color:blue'>//</span><span style='color:red'>/</span><span style='color:gray'>M3</span>
27levels web design
someguy is offline   Reply With Quote
Ahh.. My first BMW.. But.. now big problem(s)... Trigabby 3-Series (E36) 19 09-21-2005 12:21 PM
