Blower Problem? - BMW Forum - BimmerWerkz.com
Old 01-17-2011, 03:48 PM   #1 (permalink)
joe01952 is on a distinguished road
Blower Problem?
Hi
So I changed out the Final Stage Unit..(97 328is) and blower still didnt work at any speed so I have the Blower motor out now and have to replace except when I jump it to the battery it runs.. please someone tell me its an amp thing or I rustled the brushes around enough to get it to work that was a PITA !!
Please let me know where else to look if the new motor doesnt work?
Could the FSU have gotten burned out by the bad motor?
BTW does anyone know where I could look for the left side of the blower box(Whats it called?) I broke the damn little plastic tab that hold the door cable..!!
Thanks
Joe
joe01952 is offline   Reply With Quote
Old 01-17-2011, 04:23 PM   #2 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
Originally Posted by joe01952 View Post
Hi
Thanks
Joe
Assuming you checked all your fuses, have you checked the relay?
jbg
Old 01-17-2011, 04:28 PM   #3 (permalink)
In the link below, do you see the tab you are referring to?
RealOEM.com BMW E36 328i HOUSING PARTS - AIR CONDITIONING
link with blower issue:
http://forums.bimmerforums.com/forum....php?t=1264309
Old 01-17-2011, 05:07 PM   #4 (permalink)
Update
Ok.. So I put a test light on the wires coming from the blower
The light brightens as I up the fan and dims as I shut it down..
So I can assume the blower motor?
Joe
Old 01-17-2011, 05:14 PM   #5 (permalink)
Joe
Yes.....when you jumped the blower motor earlier, that was a direct 12 volts, sounds like a bad motor.
jbg
Old 01-17-2011, 05:34 PM   #6 (permalink)
Thanks
Thx for the heater box diagram, it looks like I have to buy the left upper housing.. but I'll stop at the dealer and check it out.. I did epoxy it but I think Ill spend the $60.. in case the epoxy cracks its alot better than taking the damn thing apart again!!!
Thanks Again.. Joe
Old 01-17-2011, 05:44 PM   #7 (permalink)
Thanks Again.. Joe
You are welcome.......
good luck,
jbg
Old 01-18-2011, 08:30 AM   #8 (permalink)
Patrick-BMWPartsSource is on a distinguished road
Hey if you need any further help feel free to email myself or our Certified Master Technician on staff. he will respond within 2-4 hours of receiving your email.
Technician:
Mason@bmwpartssource.com
To place an order or get a price quote:
pcasey@bmwpartssource.com
Our OEM BMW parts and accessories are starting at 10% over cost !!!!
Patrick-BMWPartsSource is offline   Reply With Quote
Old 01-22-2011, 02:42 PM   #9 (permalink)
Help!!
Ok.. so I put the new blower motor in and NOTHING!! So I checked all the fuses, and swapped the relay w/ the horn relay to see it it was the relay , no luck horn works with blower relay... I just haven't gotten to fuse 48 under dash? too damn cold here today... but could it be the climate control panel? all the lights work things see to come on and go off, the panel does make a buzzing sound even for 30 seconds after turning the car off. Could the control panel make just the blower not work, buit everything else does?
Thanks
Joe
Blower problem liljavier 3-Series (E46, E90) 5 02-27-2009 02:53 PM
Blower motor problem froderickskulldigger M-Series (M1, M3, M5, M6) 1 06-19-2006 03:49 PM
Need Help! Problem With Blower, Heater. DiRay 3-Series (E21, E30) 4 02-15-2005 04:13 PM
Intermittent Blower Problem ianrigg 3-Series (E36) 0 05-13-2004 04:55 AM
Heater Blower Problem mozzo 3-Series (E36) 0 05-06-2004 05:52 AM
