Bilstein Touring Shocks - BMW Forum - BimmerWerkz.com
Old 11-28-2004, 07:53 PM   #1 (permalink)
funtoos's Avatar
funtoos is an unknown quantity at this point
Send a message via AIM to funtoos
hey guyz,
i think my 92' 325i needs new struts and shocks... i was doing a little search and the best i could come up with was bilstein Touring Class shocks for $289... everything else was more than $500 (no springs)...
are these any good? can i get a better deal than this? or are these not worth it and thats why they are cheap?
please post if any specific place has better deals...
thanx
'04 330Ci
'00 Kawasaki ZX9-R
Now looking for an M3
funtoos is offline   Reply With Quote
Old 11-28-2004, 08:28 PM   #2 (permalink)
viali8 is an unknown quantity at this point
Exclamation
i have been looking at struts for the pas month now and comparing different brands. form what i gathered from my research on this forum, it seems that the bilstein touring glass will give you that same factory ride. the HD and Sport shocks/struts will give you a stiffer ride. the sport shocks/struts will lower your car too. hope this helps. not sure if this is true for your model bmw. by the way i have an e30.
viali8 is offline   Reply With Quote
Old 11-28-2004, 08:55 PM   #3 (permalink)
Speedy-325is's Avatar
check shox.com
they have good prices but are in CA.
Old 11-28-2004, 11:37 PM   #4 (permalink)
theogill is an unknown quantity at this point
Send a message via MSN to theogill
You'll lower your car only if you get the sport springs to accompany the bilstein sports. My sense is the Touring aren't bad, but not an upgrade.
I wouldn't get them. Get the Sports and H & R sport lowering springs if you can.
BTW: I have a set of rear used Boge shocks(less than 10K) , and original BMW sport suspension springs with 50K on them. I replaced them with Dinan stage 1 suspension.
98 328i, black/black, manual, canadian sport pkg, ECIS intake, koni sport adj's, dinan springs, oe/oem clears.
Considering: tms shark,M 17" wheels, larger sway bars.
theogill is offline   Reply With Quote
Old 11-29-2004, 07:57 AM   #5 (permalink)
funtoos's Avatar
[snapback]239264[/snapback]
theogill,
how much do u want for them?
rear shocks?
spring - would that lower my car? how much?
'04 330Ci
'00 Kawasaki ZX9-R
Old 11-29-2004, 10:56 AM   #6 (permalink)
Tourings are OEM Replacement shocks, don't use them with performance springs as they are a waste of money. Get Bilstein Sport.
The only difference is that Tourings are Gas pressure, OEM is not.
Bry
Old 11-29-2004, 11:12 AM   #7 (permalink)
funtoos's Avatar
I was not planning to use performance springs... but then i don't know (if i get a good deal somewhere i might)...
but if i just wanted to replace the struts/shocks and keep the original springs (since they dont go bad or do they?), do you think the bilstein touring are worth it? or is it a waste of money and i am better off just getting some others for cheaper price?
thanx guyz
'04 330Ci
'00 Kawasaki ZX9-R
Old 11-29-2004, 12:54 PM   #8 (permalink)
thanx guyz
[snapback]239379[/snapback]
A cheaper solution is SACHS Boge's Automatic gas shocks. I've used them before with both OEM springs and aftermarket lowering springs. They work great with both combinations. They are slightly stiffer than stock but are sold as OEM replacement shocks as well. They have lifetime warranty like the Bilsteins and are a fraction of the price.
$150CDN each for Bilstein TC and $90CDN each for Boge Auto Gas.
Old 11-29-2004, 01:56 PM   #9 (permalink)
Per your PM, you could get the springs and rear Boge's from me, and then buy the front Boge Struts. SOunds like they're a good match according to earlier post.
By the way, why d oyou think you need new shocks? How many miles on your car? It's possible if you have a sloppy front or back (no offense :P ) that it could be other front components, like control arm bushings, tie rods, etc.
Now, will my units from a 98 328i fit your 92? Also, you'll want to change your rear shock mounts (RSM's) with better ones (do a search).
Considering: tms shark,M 17&quot; wheels, larger sway bars.
Old 11-29-2004, 11:05 PM   #10 (permalink)
thekid's Avatar
I have them, I have been satisfied with them. They are 15% (translates to not much stiffer) stiffer than stock and ride the same.
325is bilstein shocks theruss1an1 3-Series (E36) 7 09-21-2004 09:45 PM
sport shocks vs. touring? 87bimmer 3-Series (E21, E30) 7 07-08-2004 09:34 PM
Bilstein Touring Shocks Wil524 Product Reviews 3 07-06-2004 11:45 AM
Anybody bought Bilstein Touring Shocks? mostwired 3-Series (E36) 4 03-10-2004 11:32 PM
bilstein shocks for e39 h2oskidad 5-Series (E12,E28, E34, E39, E60) 0 08-06-2003 09:07 PM
