Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 09-07-2005, 08:37 AM   #1 (permalink)
Idle Member
Photos: 0
wcre34 is an unknown quantity at this point
battery lost charge..proper way to charging it
My car battery ran lost charge, im changing the alternator soon but i have no power and dont have another car to help me jump start. I do have a battery charger my question is can i just pull the battery out and charge it outside the car or should i just leave the battery and charge it.. if i leave it in the car should i charge using the jumpstart instruction where u hook it under your hood/bonnet or directly to the battery in the trunk/boot ??thnk
wcre34 is offline   Reply With Quote
Old 09-07-2005, 10:00 AM   #2 (permalink)
nukeduster's Avatar
Car: 95 Daytona Violet M3
Photos: 0
Leave it in the car, connect it under the hood to the correct jump start hookups. Keep in mind most batteries aren't meant to be deep cycled(used until dead).. batteries never hold a full charge after that.. so if your alt is bad, and you don't want to keep ruining batteries, change it ASAP.
Old 09-07-2005, 11:56 AM   #3 (permalink)
Idle Member
Photos: 0
change the batt too u mean? i was thinking about going optima battery i guess this is my chance
Old 09-07-2005, 12:37 PM   #4 (permalink)
rej487's Avatar
Photos: 0
rej487 has a spectacular aura aboutrej487 has a spectacular aura aboutrej487 has a spectacular aura about
Send a message via AIM to rej487
THat's exactally what he means. Because once that battery dies it will no longer hold 100% charge EVER AGAIN!!! Best you'll prob. get is about 65 - 75% charge out of ur battery...
rej487 is offline   Reply With Quote
Old 09-07-2005, 12:46 PM   #5 (permalink)
Idle Member
Photos: 0
i reckon so oh well gonna go get optima battery tomrrw if i could then as far as fixing my alternator goes need to figure out what the number of voltage regulator it is.. so i could replace it..
Old 09-07-2005, 02:07 PM   #6 (permalink)
Administrator
97alpineM3's Avatar
Car: Blah
Photos: 0
97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light
Optima batteries are great... I've driven for more than 30 mins with no alternator with one of those...
Les
1997 E36 M3 1990 E30 325i
Old 09-07-2005, 07:47 PM   #7 (permalink)
Power Shifting
Cruzin 323is's Avatar
Photos: 0
i would def recomend changing the altenator first... then buy the new battery or do it the same time.. and start fresh!
-SOLD..
R.I.P Fast 6
Old 09-07-2005, 09:05 PM   #8 (permalink)
6th Gear Member
e36_m3_Turbo's Avatar
Photos: 0
Keep in mind, alternators dont charge a battery, they only keep a fully charged battery full.
Image hosted by Photobucket.com
No longer red.
Old 09-07-2005, 09:21 PM   #9 (permalink)
Idle Member
Photos: 0
yea but if the voltage regulator went bad the alternator wont charge the battery or charge it too much but in this case it havnt show sign of dimming lights and all.. but the battery charge lights came on.. so before i jump to a heavy thing i want to do battery first to see..but the BMW shop i took my car to get radiator and maintainance done said it was the regulator problem without a diagnostic either he was going by experience i cant really tell since this is my first bmw..
vB code is On
Battery Losing Charge mlg106 3-Series (E36) 3 05-15-2005 10:40 AM
Battery Charge Light Came On PhunkDJti 3-Series (E36) 2 10-29-2004 07:55 AM
318i-Not charging Hypnogaja 3-Series (E21, E30) 15 10-27-2004 03:18 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
