Battery Light Comes On During Acceleration - BMW Forum - BimmerWerkz.com
Old 04-04-2005, 11:42 PM   #1 (permalink)
mostwired is an unknown quantity at this point
Thumbs up
My battery warning light comes on for a split second when I start accelerating in first gear. It only happens in the first, and only when I accelerate moderate/hard. Is there a high load on a battery during acceleration in first gear for some reason? (maybe, my alternator doesn't provide enough current for a moment?)
I replaced regulator and brushes a year ago - so should be like new. Alternator also cranks out healthy voltage when I checked it, even with all other equipment draining it (heater, radio, lights). All fuses are fine. What could it be?
mostwired is offline   Reply With Quote
Old 04-05-2005, 01:10 AM   #2 (permalink)
ex owner/admin
Furious's Avatar
hmmm, could be the alternator again, it could be overcharging. but its sooo hard to tell without a proper diagnosis, it could be just a loose wire also , who knows, do you have any fault codes?
Old 04-05-2005, 04:56 AM   #3 (permalink)
docrobot's Avatar
docrobot is an unknown quantity at this point
Just a guess, but your belt may be slipping.
Only in First, where the acceleration is the highest points to the belt - maybe...
docrobot is offline   Reply With Quote
Old 04-05-2005, 02:50 PM   #4 (permalink)
No fault codes at all. I didn't think about possibility of overcharging... might be possible - especially that the A/C is automatically disabled for the period of hard acceleration - just the fan blows air. I have replaced the belt about a year ago and checked the tension again. Strange thing is that the battery light seems to stay on longer than before - two months ago I could barely notice something blink - no it became more pronounced.
Old 04-05-2005, 04:38 PM   #5 (permalink)
aheath's Avatar
aheath is an unknown quantity at this point
Send a message via AIM to aheath
Man, think cheap fix first when approaching ANY problems.
I thought I had to replace my thermostat in my old car, turned out I just needed a new radiator cap. An expensive job or tedious job turned into a cheap one.
Check the belts!!
aheath is offline   Reply With Quote
Old 04-05-2005, 08:27 PM   #6 (permalink)
NeverLeaned is an unknown quantity at this point
Send a message via AIM to NeverLeaned
First guess would be the belt is slipping..... (which would mean the tensioner is probably shot)
Give it the hand test.... with the car off, push down on the belt with your hand. The belt should have a bit of play, but not more then an inch or so.
You can also Grab a bar of soap and hold it on the pulley side of the belt why the car is running.... the soap usually a quick fix to belt problems on the older cars that use pulley tensioners... but it could help you diagnose whether its a tensioner or something else.
1996- BMW 328IS
<img src='http://img.photobucket.com/albums/v242/gws226/TEX/neverleanedsig.jpg' border='0' alt='user posted image' />
Performance: Zimmerman Cross Drilled Rotors-- PBR Deluxes-- Cosmos CAI---- Turner Pulley Kit--- Fan Delete mod---
Beauty: 18 polished M-Parallel replicas, Inpro Euros w/ Enchanced Angel eye kit, 20% tint
Clear corners/sidemarkers ---- Eurospec (Depos)
To do list:
Suspension--- researching
UUC System U TDM- 3/05
M50 manifold converstion 3/05
NeverLeaned is offline   Reply With Quote
Old 04-06-2005, 09:21 AM   #7 (permalink)
Car: 1993 325i
victorgallas is an unknown quantity at this point
Send a message via ICQ to victorgallas Send a message via AIM to victorgallas Send a message via MSN to victorgallas
It could be a failing belt tensioner, im sure uve replaced the belt, but what about the tensioner arm itself?
Also, if not the alternator, check for corroded, loose wires. On back of alternator and battery.
And if battery is old, it wont hold charge any more, since it gets to a point of saturation, this is for real..
Anyway, if you replaced brushes and coltage regulator less than a year ago with BMW original parts, my guess is that you have some dirty, corroded wires somewhere.
If you used aftermarket parts, let me warn you, they are cheap, but they break way sooooooner too.
So put the voltmeter with the car idling, you should get something close to 14v, not above, high 13 to tops 14 volts. But even if you get a voltage reading, that wont indicate amperage flow. This means that if you have a loose, dirty, corroded wire, you will get some energy flow, therefore the voltage reading, but not all the flow, meaning, not all the amps, so you have a problem on the charging system..
Check that,. im pretty sure is something dumm..
let us know
You are a BMW driver when you become part of the &quot;Ultimate Driving Machine&quot;
Fraude an Fahren
BMW &gt; Bayerische Motorenwerke
Auf Viedersehen der herr
www.clemsonfsae.com
victorgallas is offline   Reply With Quote
Old 04-06-2005, 10:13 AM   #8 (permalink)
13.8 - 14.3V actually
1996- BMW 328IS
To do list:
Old 04-06-2005, 01:29 PM   #9 (permalink)
Car: 1993 325i
[snapback]326583[/snapback]
Yes those are the correct values, i did not have the manual on my hand,
thnaks ..
Fraude an Fahren
www.clemsonfsae.com
Battery Light 92_325i 3-Series (E36) 12 12-18-2004 01:45 PM
318i-Not charging Hypnogaja 3-Series (E21, E30) 15 10-27-2004 03:18 PM
Help - Battery Light Is On (again) Pegasus 3-Series (E36) 6 10-01-2004 11:14 AM
