Battery Or Alternator? - BMW Forum - BimmerWerkz.com
Old 02-20-2005, 02:46 PM   #1 (permalink)
sennis is an unknown quantity at this point
Send a message via MSN to sennis
Hey Guys,
Ok so I went to start my car the other day, and it wouldn't turn... Battery was dead... Or so I assume... I boost it and she starts up fine... (Runs well)... I then get to a buddies place, go in for a beer, play some video games, and when I come out my car is dead again.... So he boosts me, and I head home...
Go out this morning to start it, and she's dead again... Battery is only 3 months old... Is this a bad battery?
Im guessin best bet is just to have batt. tested, but curious if someone can decipher what the prob is just by hearing what's been going on...
Any help is appreciated.
Cheers,
Steve
"DUDE, what are we celebrating!!!!????"
sennis is offline   Reply With Quote
Old 02-20-2005, 02:54 PM   #2 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile
Send a message via ICQ to jrhaile Send a message via AIM to jrhaile Send a message via MSN to jrhaile
sounds like battery to me... when my alt took a crap, car wouldn't even start with a jump. Does all of your audio equipment work like cd player, amps, subs? if so, it's not your alt
jrhaile is offline   Reply With Quote
Old 02-20-2005, 02:57 PM   #3 (permalink)
BImmerN2B's Avatar
BImmerN2B is an unknown quantity at this point
I would say alternator because when alternators take a crap, they take the battery with them(new or not). Take a digital voltmeter and test your alternator. or it could be something that you are leaving on in the car that also could be causing that.
BImmerN2B is offline   Reply With Quote
Old 02-20-2005, 03:00 PM   #4 (permalink)
Threadkiller
bitcore's Avatar
Battery.
Your car apparently runs just fine once it's started, so your alternator is putting out the juice nessicary to operate the car, but the battery is not holding a charge, which makes it so you cannot start the car again.
There could be a simple mystery drain on the battery when the car is off, causing it to go dead again, you'll have to investigate. Regular car batteries are not designed to deep cycle (IE: drain down so very far) much at all, and every deep cycle you do will reduce it's life significantly.
Old 02-20-2005, 03:12 PM   #5 (permalink)
hey guys...
thanks alot for this... Appreciate it.
Im going to go to the dealership tommorow... My battery does have a one year warranty on it, so hopefully we find out it is the battery, and I can simply swap it for a better one...
Cheers,
Steve
Old 02-20-2005, 06:24 PM   #6 (permalink)
Rooz's Avatar
Car: 2003 M5
has your electrical system been acting weird?? like radio suddenly stops and turns back on,.... ?
VIEW MOD LIST & PICS
Originally Posted by Gregg
Rooz is offline   Reply With Quote
Old 02-20-2005, 10:16 PM   #7 (permalink)
Hi there.. Naw,, everything works great when the car is running...
Electrical system seems fine... Which tends to make me think it's the battery..
Thanks again,
Steve
Old 02-20-2005, 10:39 PM   #8 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
has to be battery.. if it was alt, nothing would work even on a jump start.. alt provides the power to those electrical devices...
Old 02-20-2005, 11:03 PM   #9 (permalink)
Rooz's Avatar
Car: 2003 M5
yeap, it's battery!
Old 02-20-2005, 11:12 PM   #10 (permalink)
rsn48 is an unknown quantity at this point
The alternator on my son's 318i car just went and it was surging, the lights was surge brighter, then back to normal. Check lites would come on for "check transmission" and "engine check light."
rsn48 is offline   Reply With Quote
Old 02-20-2005, 11:48 PM   #11 (permalink)
Power Shifting
Cruzin 323is's Avatar
a little test for u....??
1- attach jumper cables
2-start car
3- while car is on, disconnect the battery
4-(if car turns off) then its your alternator
5- if car stays on, then its the battery!
-SOLD..
R.I.P Fast 6
Old 02-21-2005, 12:49 AM   #12 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
not true cruzin... example, when my alt died, I was on the freeway. cd player flipped up and lights dimmed big time. but car ran all the way until I got it pulled into a shop. and disconnecting your battery while electrical stuff is functioning I would say is a bad idea :P
Old 02-21-2005, 10:24 AM   #13 (permalink)
Pegasus is an unknown quantity at this point
2-start car
[snapback]295947[/snapback]
You should never do this. You could fry the whole system. Check your manual. It expressly says that you should never disconnect the battery while the engine is running.
Pegasus is offline   Reply With Quote
Old 02-21-2005, 05:33 PM   #14 (permalink)
Hey Guys,
Just a little update... Took the batt to the dealer... Even though the battery was only 3 months old, it didn't hold a charge... Just a bad batt...
I had a one year warranty, so just swapped another one in, and everything works great. Thanks for the help! This site rocks!
Steve
e39 540i alternator and battery question HardStep 5-Series (E12,E28, E34, E39, E60) 5 10-11-2005 12:18 PM
Problem Two: Alternator Or Battery? atm2000 3-Series (E36) 5 05-16-2005 10:02 PM
318i-Not charging Hypnogaja 3-Series (E21, E30) 15 10-27-2004 03:18 PM
Help - Battery Light Is On (again) Pegasus 3-Series (E36) 6 10-01-2004 11:14 AM
