Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 06-26-2004, 01:26 PM   #1 (permalink)
Photos: 0
peter1loftin is an unknown quantity at this point
Smile
can some one please help my 318is is using loads of petrol and has lost all its power there is also a bad smell coming from the cat i think the garage told me the o2 sensor just before the cat is stuck on high but they say it will not make it do the things it is doing they think it is the air mass meter can any one help please.
peter1loftin is offline   Reply With Quote
Old 06-26-2004, 01:29 PM   #2 (permalink)
6th Gear Member
Kevin325i's Avatar
Photos: 0
Bad catalytic converter. It took your O2 sensor with it. Replace them both and you'll likely have your power back. I'd recomend not going OE on the cat because it's super expensive. Just find a nice after market part.
Kevin
Kevin (President TBEA)
Old 06-26-2004, 02:30 PM   #3 (permalink)
Idle Member
Photos: 0
greennvmachine is an unknown quantity at this point
Send a message via Yahoo to greennvmachine
if you mean absoulutely no power, with a bad smell, it could be your clutch
greennvmachine is offline   Reply With Quote
Old 06-26-2004, 06:30 PM   #4 (permalink)
Administrator
97alpineM3's Avatar
Car: Blah
Photos: 0
97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light97alpineM3 is a glorious beacon of light
As much as anyone on this forum can tell you what they think is wrong... the best bet when your dealing with something that pretty much puts the car to no good use.... Get it checked out by a BMW shop... to tell you whats wrong... I wouldnt exactly let them work on the car if it is something I could do my self... its a lot cheaper that way... but I'd say get it looked at.. It could be a number or problems.. from your Clutch... to your computer... GOOD LUCK
1997 E36 M3 1990 E30 325i
Old 06-27-2004, 03:45 AM   #5 (permalink)
kamikazinyc's Avatar
Photos: 0
kamikazinyc is an unknown quantity at this point
I say is your cat I had the same thing bad O2 make the unburned gas go in the cat then it eats it away slowly so make sure you check your O2 every time you tune up that goes for all of you.
The inside is busted and a chunk of it turned to the side blocking the air flow
so after I bought a after market one, it only lasted 2 months tops if that.
Go with OE find one from the junk yard buy a new O2, when you buy one from the junk knock on it and shake the shit out of it make sure the inside is not lose nothing falls out of it (crums etc)
DREMEL is South Africa Engineer's best friend
<span style='color:blue'>HID all the way </span>
kamikazinyc is offline   Reply With Quote
Old 06-27-2004, 06:36 PM   #6 (permalink)
6th Gear Member
Kevin325i's Avatar
Photos: 0
You could empty out the stuff inside the cat too..... But it's a little illegal, but if you don't have emissions testing....
Kevin
vB code is On
Does An '85 318i Have Power Steering? dsio 3-Series (E21, E30) 1 03-31-2005 10:32 AM
Best Kind Of Headlight Bulb? all4isu 5-Series (E12,E28, E34, E39, E60) 6 10-18-2004 03:26 PM
power pulleys, re they really that bad? the///man 3-Series (E36) 1 10-18-2003 10:12 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
