Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 08-28-2007, 10:26 PM   #1 (permalink)
Photos: 0
sarahbecca83 is on a distinguished road
Bad ignition switch?
When I tried to start my car today it would not start. When I turned the key the accessories turned on and stayed on even after the key was out of the ignigtion. The accessories would not turn off until I disconnected the battery. Has anyone else had anything like this?
sarahbecca83 is offline   Reply With Quote
Old 09-01-2007, 04:54 AM   #2 (permalink)
kurtdaniel's Avatar
Photos: 0
kurtdaniel is on a distinguished road
If you look on top off the starter you will see a single terminal connector with a black/red wire. Hook up a test light and see if there is power to this wire when you put the key in the START position. If you have power there and the engine does not crank, then you have a bad starter and it will need to be replaced.
If you do not have power there in the START position, then the problem could be in the ignition switch, clutch switch if it is a manual transmission or a bad Neutral Safety Switch (NSS) if it is an automatic transmission.
for more info http://autorepair.about.com/library/faqs/bl643d.htm bmw m5 radiator. Good luck
kurtdaniel is offline   Reply With Quote
Old 09-02-2007, 10:14 AM   #3 (permalink)
Photos: 0
I do have a manual and I can not find anything about a clutch switch. Can you tell me where it is located?
vB code is On
Replaced ignition switch on 2000 528I….need help please. johnex 5-Series (E12,E28, E34, E39, E60) 0 08-24-2007 11:03 AM
Ignition Switch Replacement 325eXTATIC 3-Series (E21, E30) 1 07-02-2005 01:18 PM
Diy: Replacing Ignition Switch e36surge 3-Series (E36) 11 05-25-2005 09:45 PM
Wiper And Ignition Switch Problem. Lexume 3-Series (E36) 1 02-02-2005 04:30 PM
is replacing ignition switch diy? ifonlyIhad 5-Series (E12,E28, E34, E39, E60) 0 05-31-2004 05:37 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
