bad engine pressure - BMW Forum - BimmerWerkz.com
Old 12-29-2008, 04:00 PM   #1 (permalink)
Ryderofthestorm7's Avatar
Ryderofthestorm7 is on a distinguished road
bad engine pressure
This problem came up the other day, and I really haven't been able to figure out what it is. First off, I have an automatic 318is. When the engine runs for a few minutes, a whistling noise comes from the engine bay. It's really difficult to pinpoint exactly where it's coming from.
I first thought it was the pulleys but I've noticed that when i lift off the oil filler cap, there is a noticeable pressure coming from inside the engine. The noise also goes away when the filler cap is taken off. It must be a valve that is sucking in more air than it's supposed to, but which one could it be?
Ryderofthestorm7 is offline   Reply With Quote
Old 12-30-2008, 04:54 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Could also be an air leak on the intake hoses.
Old 12-31-2008, 01:45 PM   #3 (permalink)
I have replaced all of my intake hoses already.
Old 01-02-2009, 12:36 PM   #4 (permalink)
cjscopp's Avatar
Car: 2002 525i and 1995 325i
cjscopp is on a distinguished road
You have a crankcase leak and BMW's hate them. You will need to find where the whistling is coming from, that is your problem. If you think about it, it explains itself. When you have the oil cap on, the crankcase pressure is forced to come out of whatever leak there is causing the whistle. When you remove the oil fill cap the crankcase pressure goes away as you now have a huge leak. Put the cap back on and the whistling starts again. You can get a piece of rubber hose and put it to your ear and move the other end around until you find the leak.
cjscopp is offline   Reply With Quote
Old 01-06-2009, 07:20 PM   #5 (permalink)
would anybody be able to explain exactly how the crankcase vent valve works? does it constantly suck in air like a vacuum? does it change in strength when you accelerate? what is it supposed to do during idle?
Old 01-14-2009, 10:19 AM   #6 (permalink)
Car: 1996 BMW 318i 4Dr
khaoswing is on a distinguished road
Question
Does anyone know where the Crankcase vent valve IS??? Pictures would be awsome!!!
khaoswing is offline   Reply With Quote
Old 01-15-2009, 04:41 PM   #7 (permalink)
cjscopp's Avatar
Here is a diagram. It is the valve that is circled.
Old 01-17-2009, 08:44 PM   #8 (permalink)
Car: 325i, 750iL
drivinfaster is on a distinguished road
i had to chase down an intermittent whistle on a 95 m3 auto. it would only be audible on initial acceleration, or (as i found out) when driving up onto the alignment lift. it turned out to be a rear main seal 'sucking in' air, which went away after i replaced the seal. trust me, the ccv is *MUCH* easier. i would do that first. (which is how we figured out it was the rms...)
df
drivinfaster is offline   Reply With Quote
STOP! engine oil pressure? kc740i 1,6,7,8 - Series and Mini Cooper 3 03-21-2010 02:37 PM
Engine sounds bad... SpeedInfusion M-Series (M1, M3, M5, M6) 10 08-01-2007 10:41 PM
Bad idle when Engine is HOT only!! Paraklas 3-Series (E21, E30) 0 11-14-2005 03:04 PM
From Bad Sensor To Bad Engine Control Computer Dme atifhalim 3-Series (E36) 5 07-17-2005 06:37 PM
Bad Pressure Sender? hawkmoon36 3-Series (E21, E30) 1 04-28-2005 12:55 PM
