backfire probs with my 325is - BMW Forum - BimmerWerkz.com
post #1 of 14 (permalink) Old 08-10-2008, 05:06 PM Thread Starter
daddyt06's Avatar
daddyt06 is on a distinguished road
ok, long story short. took my car to the local bmw (savage) because i had a misfire in my 4th cylinder. i myself swapped plugs coils etc. couldnt find the prob. they told me that my computer (dme) was causing a misfire in my 4th cylinder. sh*t, ok they changed it they flashed it and all together cost me 2k (comp was 1500$) so here i am mr happy driving off from the dealer with my car running fine. i get home and about 30 mins later decide to go to the store. start the car and it runs a lil ruff at first, stopped then ran fine. backed up and took off and i get a back fire at about 1400 rpms with slow accel and i can feel the car shaking as if a misfire but felt more like a timing issue. took it back the next morning and they checked it out and said that my cam timing is off and for them to get into it would be a min of 1 hour to 8 hours at 127$ per hour. before i took it to them i didnt have a backfire, only a misfire. timing was fine and now they are trying to say it wasnt connected to replacing the comp. ok, in my expierence the timing chain and timing is regulated by the comp, please correct me if im mistaken, but should i take it back to bmw and tell them to fix the problem, or are they not responsible for this prob since they fixed the misfire? all they told me was it could be a few things like bad coil, mechanical probs with engine, etc. advice por favor!
daddyt06 is offline
post #2 of 14 (permalink) Old 08-10-2008, 10:09 PM
darkhorse737's Avatar
Quoted: 2 Post(s)
Cool
what year model 325is???
darkhorse737 is offline
post #3 of 14 (permalink) Old 08-10-2008, 10:27 PM Thread Starter
daddyt06's Avatar
its a 93.
daddyt06 is offline
post #4 of 14 (permalink) Old 08-11-2008, 09:23 AM
Lower_Level is on a distinguished road
timing chain is driven off the crank, and the cams are driven by the timing chain. The computer does nothing for the cam timing; it has to be mechanically set with BMW special tool # blah blah blah. You get the idea.
Don't think that changing the DME would affect the position of the cams in any way...
Lower_Level is offline
post #5 of 14 (permalink) Old 08-11-2008, 09:33 AM
Quoted: 2 Post(s)
Unhappy
get a 2nd opinion from a reputable shop in your area, and let's see.
in fact, i am very suspicious about the dealer's logic of faulting and re-flashing the DME. I would like to know exactly what tests they did to reach that conclusion.
post #6 of 14 (permalink) Old 08-11-2008, 06:54 PM Thread Starter
daddyt06's Avatar
Well the problem im having with the dealer is that my timing wasnt off when i took it to them. the only problem was a misfire in my 4th cylinder. only after me driving the car away to my house did i get a timing problem. not even 5 miles. if the timing was off im sure they wouldve told me that and charged me another 8 hours labor to fix it.
daddyt06 is offline
post #7 of 14 (permalink) Old 08-11-2008, 10:00 PM Thread Starter
daddyt06's Avatar
so dme not affecting cam timing what could be a cause of throwing off the timing? dropped car back off at dealer told them tell me exactly what the problem is since i only had it for 15 mins and it had a new different problem.
daddyt06 is offline
post #8 of 14 (permalink) Old 08-12-2008, 10:14 AM
odd thought; but is it possible the timing chain tensioner failed & now your cams [I]aren't[I] in time anymore? It would be flukey that it happened when it did though.
post #9 of 14 (permalink) Old 08-12-2008, 08:03 PM Thread Starter
daddyt06's Avatar
well my service rep called me about 15 mins ago and said they didnt find a definite answer yet and they would have to get back with me tomorrow. im just hoping that they find out the problem and dont just say oh it could be 4 different things like before.
daddyt06 is offline
post #10 of 14 (permalink) Old 08-14-2008, 06:12 PM Thread Starter
daddyt06's Avatar
update
ok they said they couldnt find a reason for the timing problem, only thing they can do is charge me 762$ - 6 hours labor, to fix it. first 4 hours is just to remove the valve cover, which only takes an hour, but for sum reason they charge 4. and 2 additional hours for them to adjust the timing... any thoughts / suggests?
daddyt06 is offline
post #11 of 14 (permalink) Old 08-16-2008, 07:26 PM
Quoted: 2 Post(s)
Unhappy
it probably wasn't a timing prob to start with and that why they cdnt find anything!
you paid for a job that didnt get done? why is that??????? I don't want to sound philosophic but if that was the way a dealer treats a customer... man, then all i need is to get a 6th grader to open up the covers, look into the engine, put everything back together, and shove u a bill. Now, NOW that doesn't sound right
* and, from a business point of view, it isnt ethical, nor is it professional for a business to do that
post #12 of 14 (permalink) Old 08-16-2008, 08:31 PM Thread Starter
daddyt06's Avatar
Thumbs down
final draft... ok turns out 2 bad coils were working at about hald capacity, which was giving me the back fire. they took off the valve cover and checked the timing was fine, AFTER they did that they then checked the ignition coils and found the two that were malfunctioning. they had to of course replace the bolt grommets and valve cover gasket. (i just changed the valve cover gasket my self a week ago, last thursday to be exact) they then charged me 300 labor (2.3 hours) and 95 dollars for the gaskets. they did not fix the problem because i can get the coils cheaper from bavauto then there and do the work my self. so i paid $399.82 for basically nothing. they shouold have told me the coils were bad before taking off the valve cover. i already went back and told then i wanted a refund since they didnt DO anything but tell me what they should have before. so yeah, gotta wait til monday now. talk to my advisor....
daddyt06 is offline
post #13 of 14 (permalink) Old 08-17-2008, 08:15 AM
out of curiosity; how did they "test" the coils to find out they were bad? Is there a way that you could have done that in your driveway?
post #14 of 14 (permalink) Old 08-17-2008, 11:14 PM Thread Starter
daddyt06's Avatar
i guess they just swapped them with sum other ones. they didnt tell me. ill be sure to ask when i go back.
daddyt06 is offline
Newbe Here With A Few Probs xgordyx 5-Series (E12,E28, E34, E39, E60) 5 12-06-2004 12:35 PM
Window probs justin93 3-Series (E36) 12 06-21-2004 11:22 PM
Steering probs! ksamy 3-Series (E36) 6 05-11-2004 02:43 AM
