b&M short shifter - BMW Forum - BimmerWerkz.com
Old 04-24-2006, 09:16 AM   #1 (permalink)
Car: 99 BMW 323is
stracer is on a distinguished road
Send a message via AIM to stracer Send a message via Yahoo to stracer
b&M short shifter
I have one in my 99 323is. I notice sometimes it seems a little hard to get into gear. No grinding just little harder than normal. I know putting a ss in will make it more percise and little play in the stick. Anyone else have this issue.
stracer is offline   Reply With Quote
Old 04-24-2006, 02:13 PM   #2 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
did u check ur gearbox fluid?
Old 04-24-2006, 02:18 PM   #3 (permalink)
ex owner/admin
Furious's Avatar
the ss will make the feel notchier. a bit harder? well kind of, its not so easy like before, but very precise. i have the same shifter and noticed the same thing. if you find its way to difficult maybe you might have some other problem
Old 04-24-2006, 02:22 PM   #4 (permalink)
General Chaos
Car: ///M3,Corolla
my friend had the same issue when he got his SSK in actually, it turned out to be 2 things
1) the shifter needs to broken in
2) the gearbox fluid hadnt been changed/was low
Old 04-25-2006, 01:14 PM   #5 (permalink)
Car: 99 BMW 323is
where is the gearbox fluid located and what type of fluid should I put in it. my car has 85k i bought with 83k, so i have no idea if it has been changed.
Old 04-25-2006, 03:58 PM   #6 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Do you notice this more when the car is cold? The fluids need time to warm up too. You will feel more resistance when the car is cold.
Old 04-25-2006, 10:44 PM   #7 (permalink)
Ljk619 is an unknown quantity at this point
For the location of checking or even changing the fluid lift up the car whether on a lift or enough for you to crawl under. On the tranny you'll notice a bolt sticking out of the bottom that's the drain plug, the fill plug is on the side. It takes automatic transmission fluid. So yea as MPower said if it's hard to shift when cold most of the times it's the fluid needing to be warmed up, but that's normally in older cars that use gear oil as the tranny lubricant. But yea, change it if hasn't been changed and maybe it does need a break in.
///M The most powerful letter in the alphabet
Ljk619 is offline   Reply With Quote
Old 04-26-2006, 10:53 AM   #8 (permalink)
Car: 99 BMW 323is
Yea, its most noticable when its cold.
Old 04-26-2006, 10:56 AM   #9 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
My opinion... inferior shifter... thats the problem...
Just an opinion...
It will get better over time.. once it heats up and cools down multiple times... depending upon what kind of bushings you have installed.. or have not installed... derlin and or poly-u will get smother with a heat cycle.
Les
1997 E36 M3 1990 E30 325i
Old 04-26-2006, 10:57 AM   #10 (permalink)
Car: 99 BMW 323is
Yea, I have no idea if it was ever changed. like stated the car is a 99. I have had the car since oct., when I got it i put the b&m in. its only driven like one day on the weekend. From mid Dec to about feb it never came out the garage so who knows if it has been broken in all the way. Only put bout 2500k on it at the most since oct.
Shifter have a lot off play,where to buy bushings or new aftermarket Short Shifter Slow325i 3-Series (E21, E30) 15 12-17-2005 03:42 AM
Z3 Short Shifter RD_source 1,6,7,8 - Series and Mini Cooper 0 11-08-2005 12:36 PM
E30 Short Shifter RD_source 3-Series (E21, E30) 5 11-07-2005 02:47 AM
Is A Short Shifter Worth The $$? brians15 3-Series (E36) 8 04-18-2005 02:09 PM
B&m Short Shifter socalguy 3-Series (E36) 1 02-02-2005 10:04 PM
